I was re-installing the engine in my '07 Forenza...everything lined up, there was a little struggle getting it all the way together, so I started some bolts on the top, worked around the front slowly installing the bolts. Just as I was tightening the last few bolts...I heard a loud pop and fluid was flowing out of the trans on the drivers side end, and there's a huge crack....what did I do...and can it be fixed? Thanks Chobie :(
Discussion Starter #2
ok, so I took the engine out again....it apears the the cover on the trans is where the crack is...I'm thinking that when i removed the engine the first time, the torque converter moved out a bit..is there something behind it that could have maybe shifted?
I don't know anything about transmissions....so if anyone could give me some insight it would be greatly appreciated. Thanks, Chobie (Scott)
you may be able to get the trans case welded...
