Hi,
I have an 06 swift and it's idling rough and misfiring when accelerating. I'm thinking my fuel filter is clogged, but from the research I've been doing apparently it is inside the fuel filter. Has anyone tried cleaning or replacing the filter?
Does anyone have any recommendations for my issue?
I have replaced the spark plugs and run injector cleaner through too..
Misfire is coming from the coils. This is what i had to change when i had misfire in my Swift. Don't go and look for the fuel filter it's a one unit with the fuel pump in the fuel tank. You have 2 coils try to find wich one is making the misfire and change it. Hope this helped you.
Same thing happening to my car replaced the coil both brandnew, new battery, injectors clean still having missfire if gas below middle mark, im thinking something is off with the pump or filter is clogged
