I included a couple of pics.
installed picture:
I started from inside the glove box that was simple to remove. From inside there I could fit my hand up to the inside of the Silver Trim I started at the top where the blue arrows are from here you can push straight out to get the top of the trim loose. At the bottom half now by the red arrows it slides more torads the rear with those clips there. That was the easy one. Drivers side I had to use a flat scaper at the bottom by the red arrows to get it to break free since I couldn't find a way to push it out from behind the dashboard on this side.
removed picture:
Once you have both trims removed you will see several Philips head screws I highlighted this location in green circles. The radio and the AC controls are attached as one so the screws that hold them together need to be removed next it is 6 screws 3 on the left and 3 on the right. After that it was just a simple tug and she poped right out with no problems.
I hope I uploaded the pics correctly???:huh:
