Be careful, most Suzuki ones are accessed from the rear.Most marker lights lens covers are held in with tabs
Using plastic pry tool as to not scratch the paint on the car on the right side of lens,
Push the marker light to your left and then pull up or out away from vehicle.
Can be done with small screw driver with some tape on the tip.
Some people can do this with just their finger tips
Replacing the bulb will depend on the bulb they used and the method it is held in place.
Some marker bulbs are 168 or 194.
But, best to get the old one out and take that to the auto parts store
I wouldn't agree with that - more of what I have seen can be accessed from the outside.Be careful, most Suzuki ones are accessed from the rear.
In this particular case I can't agree with that either.Most marker lights lens covers are held in with tabs
Got it, just took a look at it and it does ondeed look lile i have to remove the wheel lining thing.. Damm, but ok now i know.Just so that you're aware if it - the image from the service manual is NOT the lamp you show in the first picture.
For sedans you will access from the trunk with two distinct doors being seen (one on each side) when looking from the inside of the trunk out words and looking towards the rear lights. On wagons you’ll have to unscrew the headlight assembly. Consult your manual to double check and not break anything. I believe this is mentioned under maintenance. But defiantly give it a scan because just 3 days or so while I was reading the manual I saw this exact explanation.I wouldn't agree with that - more of what I have seen can be accessed from the outside.
I'm not familiar with the Forenza but I did take a look at the parts catalog before replying earlier - the marker lights do not appear to have separate lenses and seem to be retained from the rear by a screw and spring clip, hence my statement, that it appears you'll need to get access from the back - popping the liner loose and taking a look would be the safest approach.
Perhaps the best approach is to not assume or generalize, the Forenza is not that common and if we're not familiar with it, or have no access to documentation, we should hold back rather than mis lead...
