I'm throwing a whole bunch of codes but a friend told me that this one, p0722, is probably the most important, or where we should start. I am trying to find the location of the sensor to see if i can easily replace it, any ideas would be helpful, thank you!
Furthermore, these are the other codes i'm throwing if anyone has some quick tips:
p1382 (abs wheel speed sensor)
p0174 (system too lean)
p0171 (system too lean)
p0700 (transaxle control malfunction)
what happened was that my car was making a really loud whirring sound at first, and then eventually it wouldn't shift gears as if the trans was completely slipping.
wheel speed sensor for all four wheels are inside bearing and can not be repaired or serviced. There are front and rear, left and right are same.
Front
Rear
