My sun roof will open with ease and then all of a sudden when I close it-it stops just past half way...Any ideas? I started tearing the ceiling down but not completed yet and don't know if something is stuck in the track or what? Any info would be helpful...
Thanks, Peter
Does it stop when closing itself, or are you holding the switch to close it? If it has an auto function and stops short the track might need lubing to keep things moving smoothly. It will have an anti pinch feature so if there is too much resistance (sensing a dry track like someones hand stuck in the track) it will stop closing.
If you are holding switch and it still won't close there there is an obstacle jamming the glass from gliding, or the gear system is damaged/worn out. I'd suspect something is stuck in the track. You would hear the latter as a bunch of plastic bits grinding/snapping, etc..
