On my 01 grand vitara xl 7 nothing changes when you push any of the switch buttons ie: Floor vent etc. No matter what you push it just blows out the defrost and some out the vent but nothing to the floor even when that one is pressed.each one lights up when pressed which would show that that is the one should be doing what it should. Oh i do get heat like i'm suppose to just not were it should go when direct. Any ideas ? Thanks
It blows just not were it is suppose to in reference to the directional buttons.yours i would say it is the blower motor switch.
There's an actuator that sets the vent doors, it's been a while since I looked, but I believe it's on the left side of the plenum chamber - remove the panel under the steering wheel - look through and push the buttons with the ignition on, see if anything moves - it may just be a loose link or perhaps the actuator has failed.
