Reverse indiacator lights blinking. - Suzuki Forums: Suzuki Forum Site
Old 09-03-2019, 08:18 AM   #1 (permalink)
Duner is on a distinguished road
Default Reverse indiacator lights blinking.
2004 Verona, When I shift into reverse the reverse indicator light blinks.
Does not blink in any other gear. Any ideas please?
Duner is offline   Reply With Quote Quick reply to this message
Old 09-03-2019, 11:25 AM   #2 (permalink)
I should have said , I have no trouble. codes relating to transmission.
Subject matter should have said light NOT lights.
Old 09-03-2019, 02:03 PM   #3 (permalink)
Donewrken's Avatar
It sounds like a loose wire, bad ground or bad bulb, even the indicator socket.
It could be anywhere in the circuit including the backup bulb at the rear of the car.
Another bad connection could be the switch on the shifter.
A lot of places to look at, I'd start at the bulb at the rear and check connections sometimes behind the left tail light housing.
Don
I'm here in the USA.
1991 GMC K2500 4WD 454 Xcab
1997 Trans Am LT1 auto
Old 09-03-2019, 08:09 PM   #4 (permalink)
Both backup lights are lit by the rear license plate. R blinks about once a second when shifted into reverse. I have not checked anything else yet. Thanks for reply.
