I have a 2008 SX4 crossover. It has 80K on it. My wiper squirter stopped working. At first, it just was gimpy when i first tried it, and now nothing. the back one works fine. I do hear the pump noise when i try. I will check for a clog or hose issue, but in case it is related to the next issue, I wanted to note it.
My AC died today. It comes on for a little and then blows hot air. If it is the AC clutch - about how much to repair? Can I ignore it until next summer?
When i come to a stop and turn off the radio and everything else i hear a humming from the dashboard or just beyond that. Kinda of sound like if someone is mowing the grass a half a block away and you are inside with all the windows closed - just barely there - it seems to get louder once i am at a complete stop - at first i barely hear it then 2 seconds later it hums a bit louder - what could this be?
Also, ever since i bought this new and i used the wipers heavily (not often; usually a few times in the summer and mostly in the winter with snow) I smell a really hot rubbery smell when I get out the car. Dealer couldn't duplicate the problem so they dismissed it.
I had to replace two right side tie rods recently - is that normal?
THanks.
THanks.
