sx4 sedan AWD? - Suzuki Forums: Suzuki Forum Site
Old 07-21-2009, 08:24 PM   #1 (permalink)
lumpylarry's Avatar
Default sx4 sedan AWD?
I have an sx4 sedan FWD. I can get hold of an AWD thats going to scrap. (roll over, selling off parts).
my question is, would it fit... i can get the trans, shafts diff, transfer etc. but it would have to have same wheel base, frame etc..
anybody know the specs?
2008 suzuki SX4 sport sedan 5spd FWD
2007 suzuki boulevard C50 SE
2001 suzuki swift 1.3 5spd blue
Old 07-21-2009, 10:53 PM   #2 (permalink)
zstalker's Avatar
zstalker is on a distinguished road
I've always thought that would be really cool to do. I think mechaincally it would work, you'd be switching pretty much everything after the engine: Transmission, front axles, transfer case, driveline, rear differential, rear axles, rear knuckles/hubs, etc. Once everything is in, you'll have to worry about the 4WD control module and the associated sensors and actuators. The 4WD module gets information from the BCM, ABS module, ECM, and the intstument cluster itself. If the wiring and programming is going to work out, this would be really cool...I would bet switching the control modules and wiring out of the AWD car would be the easiest way to get that all done; for all the modules would know they're still installed in the SX4 Crossover. Get the WHOLE CAR...that will save you a LOT of trouble making up wiring, etc.
If I had access to a good SX4 Sport and a rolled Crossover, I'd be all over it!
~Erik~
PS, if you need the wiring diagrams, harness layout, or anything else, let me know.
Suzuki Gold-level certified technician
dealership lead Suzuki technician
ASE Master Technician
zstalker is offline   Reply With Quote Quick reply to this message
Old 07-21-2009, 11:00 PM   #3 (permalink)
lumpylarry's Avatar
the only thing im not sure about is the wheel base. i think the sedan might be a little longer. that would make for some custom work to the prop shaft..
Old 07-21-2009, 11:31 PM   #4 (permalink)
zstalker's Avatar
oh come on, nothing a driveline shop can't handle That's the work they specialize in...I really think that would be the easiest part of the whole swap.
I was thinking: ideally to make it work in a very normal fashion you'd do the stuff I was talking about, but to make it either FWD or 4WD locked would be pretty easy (relatively)...making a switch of some sort. but I'd have to look into that too.
Making the whole swap would be really really sweet. Really sweet. Make it a turbo and you've got yourself a little monster
~Erik~
Old 07-22-2009, 08:23 AM   #5 (permalink)
evlweevil is on a distinguished road
why bother the rumor is that the sx4 sedan will be coming with awd soon. They already for 2009 have released the fwd sx4 crossover and they were talking about it coming out for 2010 (sx4 sedan awd).
evlweevil is offline   Reply With Quote Quick reply to this message
Old 07-22-2009, 10:14 AM   #6 (permalink)
lumpylarry's Avatar
lol thats the plan..
i had a closer look today, the fuel tank would also need to swapped.
But the frame support where the rear diff brackets would mount up are not there..
i would need to weld up a brace between the frame rails in order to mount the diff.
On the plus side, i measured the wheel base front to back and they're almost identical..
Also the donor car doesn't have the fancy AWD with the lock/auto switch. i thought this was just a simple viscous coupler setup and not need to replace all the control units. i dont see any electrical.. they're both 5spd, ill dig a little deeper..
5 large for the RRM turbo is a little steep right now.. might have to wait a bit.
Old 07-27-2009, 09:15 PM   #7 (permalink)
Glowmunkey is on a distinguished road
Pretty sure they all had the electronic coupling and no actual center diff, so you would need the transmission control unit - assuming it has one and it's not built into the ecu. Might need an ecu as well...
Glowmunkey is offline   Reply With Quote Quick reply to this message
Old 07-27-2009, 10:26 PM   #8 (permalink)
zstalker's Avatar
The driveshaft to the rear differential is always turning under power, all the time. The only engagement for the rear axles happens in the front section of the rear differential assembly. It uses a solenoid to operate a roller clutch in some very special fluid. The transfer unit in the rear is a sealed unit...you cannot access the fluid, nor is it available for replacement. The transfer case in the front is simply to provide something for the driveshaft to come out of.
~Erik~
Old 08-02-2009, 03:05 PM   #9 (permalink)
~Erik~
Exactly, no true center diff or actual transfer case.
Old 08-03-2009, 05:33 PM   #10 (permalink)
x_sgs_x is on a distinguished road
Can the AWD Drive system handle a turbod launch over and over.
x_sgs_x is offline   Reply With Quote Quick reply to this message
