Can you hot-wire the transfer case? - Suzuki Forums: Suzuki Forum Site
Old 04-27-2019, 10:07 PM   #1 (permalink)
Josh128 is on a distinguished road
Default Can you hot-wire the transfer case?
Can you hot-wire the transfer case somehow to force it into AWD and bypass the ECU altogether? How does the transfer case mechanically switch from FWD to AWD? This is a 09 SX4 Manual
Josh128 is offline   Reply With Quote Quick reply to this message
Old 04-28-2019, 06:45 AM   #2 (permalink)
LMP
LMP's Avatar
This is not about the transfer case. AWD is applied at the coupler, which is at the rear differential. The coupler is an electrically activated clutch. OF course one can switch 12V directly to the coupler coil but I'm not sure of the time that the coil can survive with the full 12V. IN Auto 12V is applied in a duty cycle mode, that is, equivalent to reduced voltage based on conditions. In lock mode, I have not tested the actual duty cycle but if I were the designer, I would make it proportional to throttle. So...while your proposal has been also in my head at times, I would not risk abusing the coil.
Looking for the electrical diagram....will post later.
EDIT: everything here http://www.avigex.ca/sx4/AWDtrouble.pdf
NOtice there is a temperature sensor that limits the amount of AWD . This protection would be inactive if a direct 12V feed was installed....
Old 04-29-2019, 02:05 AM   #3 (permalink)
Thank you for explaining that, I understand how it works much better now. I'm unable to use the AWD normally via the switch as there's problems with ESP that I'm not interested in fixing. At this point, I'm going to install a switch in my dash to give that coupler 12V directly and I'll just be mindful of when and how long I keep it on. I don't need AWD very often, only to power through snow or up a steep slippery hill etc. I own a parts SX4 so if something goes wrong I have a replacement coupler handy.
From your description of how the clutch engages, I understand that the voltage you apply to the coil effects how much pressure the clutch engages with. So if the car isn't moving or under load and there's a full disproportionate 12V on the coil, it will just heat things up and cause unnecessary wear and heat. If I'm understanding this right, when there is no voltage on the coil it should be completely disengaged? So the 4WD control module basically modulates how much voltage the clutch coil requires in relation to variables like the AWD switch position, load, speed, coupler temp, wheel slip, etc. I see how the 4WD module maximizes the life of the coupler.
Am I on the right track here?
Old 04-29-2019, 02:56 AM   #4 (permalink)
yes and no.
Applying 12V directly to the coil will kill it in pretty short order due to over heating. I would expect it to last about 5 minutes. The controller varies the amount of current the coupler draws to control its "clamping" force. Its like a light dimmer, voltage stays the same, but the current gets varied.
Why not fix the ESP issue? what symptoms do you have? if you have a parts car then you have sensors, tone wheels and all the necessary bits to fix it.
I can't fathom why you say "i'm not interested in fixing it" when you seem willing to destroy a rather expensive AWD clutch pack by "hot wiring" it directly to a 12V supply rather than correcting the root cause of your lack of AWD.
2013GV is online now   Reply With Quote Quick reply to this message
Old 04-29-2019, 04:22 AM   #5 (permalink)
Originally Posted by 2013GV View Post
yes and no.
This is an 09 SX4 AWD Manual. ESP doesn't work because several sensors are missing like the one in the center of the car right above the airbag control module. There's a instrument cluster from an automatic AWD in there that doesn't even have an ESP light and I'm sure that doesn't help anything. The parts car is an 07 SX4 and it turns out that the only difference I could find between model years is armrests and the gforce sensor for ESP. They're different sensors with different wiring unfortunately.
I'm not interested in buying the sensors needed, buying a instrument cluster specifically for a manual SX4 with AWD and ESP, then finding and paying somebody to program it. I'd rather program a raspberry pi to be a basic 4WD control module that watched speed and accelerator position via OBD, then regulate the amps to the coil accordingly. I'd rather spend time on an acceptable workaround then spending a bunch of money restoring the car to stock functionality.
Now I'm thinking of having 2 or 3 switches that each allow different amounts of current, then I could manually switch them depending on how much current I need. I don't need to use AWD heavily, what I have in mind is like flicking it on when starting on an icy hill. I realize that I probably sound like a loon. How many amps do you think this coil takes with no resistors?
Old 04-29-2019, 09:27 AM   #6 (permalink)
aquanaut20's Avatar
Typically ~ 10 amps on a PM, which could be manager by controlled mosphets.. rather than a series of switches on dash..
... Philip
.... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 04-29-2019, 03:09 PM   #7 (permalink)
LMP
LMP's Avatar
THis unit would be an easy fix
https://www.amazon.com/dp/B00F839VNQ...detail_4?psc=1
Old 05-01-2019, 11:01 PM   #8 (permalink)
Thank you! That's exactly what I need. I'll post some pictures of it when it's done.
Old 05-02-2019, 08:00 PM   #9 (permalink)
jimmyE is on a distinguished road
Get a new 4WD SW !!!
jimmyE is offline   Reply With Quote Quick reply to this message
Old 05-03-2019, 12:23 AM   #10 (permalink)
What's 4WD SW?
Similar Threads
Thread Thread Starter Forum Replies Last Post
replacing 1 wire o2 sensor with a 4 wire one zaharel91 Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 26 08-25-2015 03:24 PM
Tires: You can't always get what you want.. Snoopygolf 1G (2001-2006) XL-7 7 05-30-2014 01:49 AM
Can I use GL-5 Gear Oil in Transfer Case JasinC19 Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 14 02-19-2012 01:30 PM
need wiring diagram for 89 sidekick,wire gets hot warlockpain Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 13 04-18-2007 11:36 PM
Exotic cars you've seen, and you know you cant take on... ever. Zipper Street Encounters & Competition Racing 17 08-21-2006 03:42 PM
