Idler pulley: grooved or Smooth 2010 SX4 - Suzuki Forums: Suzuki Forum Site
Old 04-15-2019, 10:53 PM   #1 (permalink)
bco2jco is on a distinguished road
Default Idler pulley: grooved or Smooth 2010 SX4
Has anyone replaced the idler pulley on a 2010 SX4?
I intend to replace my IDLER PULLEY, serpentine belt and tensioner pulley.
Rockauto list two types of idler pulleys, smooth or grooved. Does anyone know which one is needed for a 2010 SX4? Thanks for your help.
My car is a 2010 SX4 AWD, Air conditioning and power steering.
bco2jco is offline   Reply With Quote Quick reply to this message
Old 04-15-2019, 11:18 PM   #2 (permalink)
aquanaut20's Avatar
Open your hood and look...
... Philip
.... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 04-15-2019, 11:31 PM   #3 (permalink)
... Philip
Yeah umm thanks i guess for that brilliant suggestion. If it were that simple, I think I would have done it already.
But you cant see the pulley from looking under the hood. You need to look from underneath the car to view the pulley. You need to raise and support the car properly, remove the front right wheel, then remove about 10 screws or bolts holding on the plastic splash guard. Then you can see the belt and pulleys. I just wanted to order parts online so I have them for the weekend when I will have a chance to change it.
Old 04-16-2019, 01:44 AM   #4 (permalink)
mirror and a torch.....
Old 04-16-2019, 04:12 AM   #5 (permalink)
Darrell.'s Avatar
Probably require both. Being in the USA it will be the 2.0l but could I believe be either the j20a or j20b engine.I don't know if they share the same idlers . I can't help much more at present as I'm just using my phone.
2005 Grand Vitara MT 1600se.
Old 04-16-2019, 04:21 AM   #6 (permalink)
usual rule of thumb, if the outside of the belt is riding on it, its smooth, if the inside of the belt is on it, its grooved.....check your routing diagram in your owners handbook, or look at the belt itself on the car, its pretty obvious.
J20b variants, grooved tensioner, smooth idler
https://www.suzuki-forums.com/suzuki...ml#post1513949
yes darrell, its one of your pics i'm shamelessly reposting
Old 04-16-2019, 07:10 AM   #7 (permalink)
LMP
LMP's Avatar
2010 is J20B. Both tensioner and idler ride the back of the belt...so smooth. I do not see how they can offer a grooved one. And no, J20A and B do not have the same tensioner. Hard to find and most of the times aftermarket lists only the J20A tensioner.
J20B tensioner on the right below (picture borrowed from other forum)
www.avigex.ca/sx4/tensioner.jpg
and this one from another forum member....it looks there are 2 idlers..!!
www.avigex.ca/sx4/belt route j20B.jpg
just for comparison, here is the J20A route
www.avigex.ca/sx4/beltJ20A.jpg
I see that ROckAuto lists both idler and tensioner (pulley alone)....but I also see the same part number comes for their J20A and J20B tensioner replacement....so I'm not sure of the exact fit...the larger diameter of the J20A original..if transferred to a J20B...might crank the tensioner a bit too much, let alone clearance ....????
Old 04-16-2019, 09:29 PM   #8 (permalink)
Thanks all for your help. So yes it appears (both) idler pulleys are smooth. I did not realize there were two! My parts are ordered now so it looks like I will just buy another one locally when I get the belt off and get an up close look. Thanks.
Old 04-17-2019, 02:39 AM   #9 (permalink)
check the tensioner carefully, they do get "soggy" with age and lose spring tension.
Old 04-17-2019, 04:33 PM   #10 (permalink)
ok, i will. I had not counted on replacing the tensioner itself, but I did order a tensioner pulley. Car has 136k on it and none of these components have been replace before. Except I think early on 2011 or something, there was a recall for belt or tensioner. I dont remember.
Similar Threads
Thread Thread Starter Forum Replies Last Post
anyone have an idler pulley part number? can't find one unclebens 2G (1999-2005) Vitara & Grand Vitara 28 11-28-2014 06:54 PM
timing belt idler pulley replacement 200solomiles Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 6 04-25-2010 03:54 PM
accessory drive belt idler pulley 1.8L engine Rouelibre Suzuki Esteem & Baleno Forum 4 02-17-2009 11:20 AM
idler pulley won't slip off vance 2G (1999-2005) Vitara & Grand Vitara 2 02-15-2009 12:27 PM
96 Sidekick Sport Need Idler Pulley 96 Suzuki Sidekick Sport Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 5 09-02-2008 03:14 PM
