J20A versus J20B - Suzuki Forums: Suzuki Forum Site
Old 01-25-2019, 01:53 AM   #1 (permalink)
ss2115 is on a distinguished road
Default J20A versus J20B
Hi.
Our SX4 is a 2009 with J20A engine and auto transmission.
Does a J20B also fit?
Does it bolt up all the same to engine mounts and bellhousing of the auto?
Does it use the same ECU?
Reason to ask is out J20A is using oil and now needs new timing chain guides etc. I can get a J20B with only 65,000klms on it at a great price.
ss2115 is offline   Reply With Quote Quick reply to this message
Old 01-25-2019, 02:00 AM   #2 (permalink)
Originally Posted by ss2115 View Post
Hi.
I know they have a different head, different profile cams, different cam sensor, you may or may not have hydraulic valve lifters, the intake manifold is different (plastic) on the newer motor and a different shape as well from memory. I am not sure if you can fit the A manifold to the B heads, I suspect they are different bolt patterns.
I think (but not sure) that the block is the same. You will need to swap the head across (which means doing cam chains as well) as I don't think the J20B stuff works on the J20A ECU. No doubt if i'm wrong someone will correct me on this.
Old 01-25-2019, 02:17 AM   #3 (permalink)
Our Manifold is also plastic - quite a large affair with the long and short runners and switching valve. But I have no idea if its the same one as a J20B or the same bolt pattern.
If I have to change heads then I may as well overhaul this J20A. I was looking for a shortcut given the J20B engine is available to me at a great price.
Old 01-25-2019, 09:35 PM   #4 (permalink)
USMC5811's Avatar
USMC5811 is on a distinguished road
J20b is entirely different animal. Including attaching parts.
2000 Tracker 2 dr. 2.0 Auto, 4x4. Sometimes it works, sometimes it makes me do the work.
USMC5811 is offline   Reply With Quote Quick reply to this message
