Intake cam problems - Suzuki Forums: Suzuki Forum Site
Old 10-22-2018, 07:37 PM   #1 (permalink)
slotech88 is on a distinguished road
Default Intake cam problems
Hi everyone i put new valve seals on my suzuki sx4 le with j20b engine 2012 everything align perfect except my intake cam i pu a picture so you can help me with this dilema thank you guys.
slotech88 is offline   Reply With Quote Quick reply to this message
Old 10-22-2018, 08:39 PM   #2 (permalink)
your timing appears to be out. DO NOT TURN THE ENGINE OVER until it is corrected. How did you time it? did you not set it to TDC and confirm the marks all lined up before removing the head to change the seals?
Old 10-22-2018, 09:14 PM   #3 (permalink)
Yes i did but in the process of dissasembly i dissasemble the phazer and yes it was tdc.
Old 10-22-2018, 10:47 PM   #4 (permalink)
why did you disassemble the variable cam unit? there was no need to. Is the engine still at tdc?has it been turned at all with the timing like this?
Old 10-23-2018, 01:56 AM   #5 (permalink)
Just the necesary to try to align the marks i didnt know tha it was a whole unit. Now can i still fixed.
Old 10-23-2018, 02:32 AM   #6 (permalink)
if you have rotated it any more than a 1/4 turn, then you may have problems.
You need to read the manual carefully and work out what you have done wrong, and re-assemble it all properly. If you need to turn the engine any more than a 1/4 turn, you will need to remove the camshafts so all the valves are closed, otherwise you will hit them with the pistons and cause serious damage.
Old 10-23-2018, 02:45 AM   #7 (permalink)
My guest is they are all closed because i change all the valve stems and when i put the springs the valve has to be all tje way up correctme if im wrong if you see the picture the mark is so close to be where it needs to be and you right i didnt read the manual carefully.Now i have the wife breathing on my neck. I jus need a litle help. I have i forgot that i have obd5 program thats my source for diagrams pics an everything else .
Old 10-23-2018, 01:03 PM   #8 (permalink)
some valves will still be open due to where the cam lobes are sitting. 1 tooth out of alignment is enough to bend valves in these engines.
All the valves will be shut before you fitted the cams, once you fit them, then some valves will open.
Old 10-23-2018, 01:06 PM   #9 (permalink)
What you guys sugest i do some info on repair please.
Old 10-23-2018, 01:16 PM   #10 (permalink)
take cams out, set engine to TDC on correct cylinder according to the manual, check the cam gear to camshaft alignment, refit the cams in the correct positions. Removing the cams is the only way you can turn the engine without bending valves.
Read the manual and follow its procedure to set the timing.
