ECU code reader - Suzuki Forums: Suzuki Forum Site
Old 08-19-2018, 03:43 AM   #1 (permalink)
Tubby885 is on a distinguished road
Default ECU code reader
My 2006 sx4 has had the engine light on for a few months.An MOT tester has told me that new rules will make this an instant fail.
Does anyone use a code reader that plugs into the obd socket?
I have an obd cable that plugs into a pc.Is there an ECU program I can download?
The engine light went off for 3 days when i fitted a new battery.Performance and fuel economy seem unchanged.......Thanks
Tubby885 is offline   Reply With Quote Quick reply to this message
Old 08-19-2018, 07:59 AM   #2 (permalink)
LMP
LMP's Avatar
the easiest move is to buy a code reader.....you can have a basic one..gives code number ...for around 50$...but we do not know where you live nor details about what you drive.
Old 08-19-2018, 04:06 PM   #3 (permalink)
2006 SX4 hatchback
England
Old 08-19-2018, 08:40 PM   #4 (permalink)
USMC5811's Avatar
USMC5811 is on a distinguished road
Amazon is your friend. Or Ebay.
2000 Tracker 2 dr. 2.0 Auto, 4x4. Sometimes it works, sometimes it makes me do the work.
USMC5811 is offline   Reply With Quote Quick reply to this message
Old 08-19-2018, 09:23 PM   #5 (permalink)
aquanaut20's Avatar
You will be doing your self a disservice in buying a code reader, spend wisely and get a live data scanner..
Codes do not support a fix, just a direction for diagnosis, most often shot gunning parts based on codes just cost you unnecessary money..
...Philip
.... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 08-20-2018, 01:09 AM   #6 (permalink)
Would a code tell me what the fault is and therefore what part needs replacing?
Old 08-20-2018, 02:11 AM   #7 (permalink)
they give an indication as to the issue, and as Aquanaut said, do not indicate which bit is faulty, you need to follow the diagnostic flow charts for that to determine the likely culprit.
I have an interesting case in point, I have another make throwing a TCC solenoid code, and i have now proved its in the wiring loom, after the owner has replaced the torque converter, and the solenoid at substantial cost. My checks proved it was intermittent and since running an ugly piece of wire from the trans to the ECU, the fault has not come back in 2 months and 5000 kms. So codes help, but do not indicate the faulty component.
2013GV is online now   Reply With Quote Quick reply to this message
Old 08-20-2018, 02:38 AM   #8 (permalink)
So it looks like I need a data scanner.Can anyone recommend one?I assume they come with instructions on how to use them and interpret the data.
Old 08-20-2018, 03:16 AM   #9 (permalink)
https://www.amazon.com/FOXWELL-Autom.../dp/B00UJV3FUC
this is the one i use for basic stuff, and it allows me to bleed ABS brakes too
Old 08-20-2018, 10:18 AM   #10 (permalink)
isdjww is on a distinguished road
If you have a smartphone, you can get an app pretty cheap. I then spent $15 for an OBD to bluetooth adapter.
isdjww is offline   Reply With Quote Quick reply to this message
