sx4 slow crank with no start - Suzuki Forums: Suzuki Forum Site
Like Tree1Likes
Old 08-17-2018, 07:24 PM   #1 (permalink)
Ursula is on a distinguished road
Default sx4 slow crank with no start
My car is a daily driven car, was working great, started fine until I parked it for a week. Now, ready to go back to work and the car won't start.
This is what happens when I try to start it;
- The starter is running slow compared to before it was parked... seems laboured.
- First thought was the battery. Tried jumping it with our other vehicle,no go.
My battery was old so no problems to get a new one. After replacing the battery, cleaning all the connections there was no change- starter sounds slow and car won't start.
-the engine sound is : rrrr, rrrr, rrrr, chuff and repeat.
-The cranking voltage for the new battery is 10.5 volts.
-Tested the spark plugs: all fired and were getting fuel- could smell the gas.
-We can hear the fuel pump run and shut off after 3 or 4 seconds.
-The air filter was dirty, took it out for testing, will replace with a new one.
-Code scanner gave no code.
-Engine Immobilizer light comes on- doesn't flash.
Any ideas why sitting for 1 week would cause this starting problem?
My car is a 2008 Suzuki SX4, 352 000 Km, We live an hour north of Toronto.
Still think she has lots of life left in her !
Ursula is offline   Reply With Quote Quick reply to this message
Old 08-17-2018, 09:34 PM   #2 (permalink)
check all connections to the starter and earths, maybe pull the starter and check it, quite possible its gone faulty sitting for a week. (or the solenoids sticky or has a bad internal contact, or brushes are dirty/worn.) Bit of moisture from the air into all that old brush dust, can and does happen after sitting for a few days. I've had one starter in the last month do the same thing, fine that morning, wouldn't turn over after work. Brushes were worn, and the last start finished it off.
Old 08-18-2018, 12:04 AM   #3 (permalink)
john yayay's Avatar
john yayay is on a distinguished road
Originally Posted by Ursula View Post
My car is a daily driven car, was working great, started fine until I parked it for a week. Now, ready to go back to work and the car won't start...
Thank you for all the details of your symptoms.
Another possible test is to pull the plugs and check if the starter is still labored without compression.
Originally Posted by 2013GV View Post
check all connections to the starter and earths, maybe pull the starter and check it, quite possible its gone faulty sitting for a week...
My thoughts too. A lot of current is required to spin a starter. A loose or dirty connection can make a big difference.
For auto issues, I found that sharing a recording (audio or video) can be helpful too.
2007 SX4, MT, AWD
john yayay is offline   Reply With Quote Quick reply to this message
Old 08-18-2018, 07:35 AM   #4 (permalink)
Did the test of pulling the plugs.
It is still labored without compression.
Removing the starter next, will update later with the results.
Old 08-18-2018, 10:57 AM   #5 (permalink)
Here is the link to what the car sounds like when we try to start it.
It seems so close to starting. (22 sec video)
https://youtu.be/99sj3z1tJek
Old 08-18-2018, 11:53 AM   #6 (permalink)
john yayay's Avatar
Thanks for the video, that helps.
I would look at the starter next too.
2007 SX4, MT, AWD
Old 08-18-2018, 02:52 PM   #7 (permalink)
aquanaut20's Avatar
If you have access to a d/c amp clamp, measure the current draw on the starter..
Then perform a voltage drop test on load side of starter circuit..
… Philip
.... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 08-21-2018, 03:00 PM   #8 (permalink)
New starter installed. Same problem, car doesn't sound any different... still won't start. Any ideas where to go next ?
Old 08-21-2018, 04:06 PM   #9 (permalink)
john yayay's Avatar
If you have spark and fuel, the next thing I would check is timing.
The SX4 has a timing chain, which should last longer than a belt, but not forever.
I am not certain, but can you tell if the timing chain jumped a tooth by using a timing light while someone else cranks the engine? Can you do a compression check on each cylinder?
You definitely have enough Km on the engine to make it a possibility.
I don't know that an external load (AC, alternator, PS) could cause enough load on the engine, but you could try removing the belt and see how the engine cranks.
2007 SX4, MT, AWD
Old 08-23-2018, 05:55 PM   #10 (permalink)
cas1234's Avatar
cas1234 is on a distinguished road
Just curious - did you try and wait in between start attempts for a few seconds? It sure sounds like it is not getting fuel. Failing fuel pump can start out like that. I am sure you tried everything, but still... Fuel filter? Bad gas? If it is not the spark it must be the fuel. Let us know when you figure this out.
cas1234 is offline   Reply With Quote Quick reply to this message
