Hi. Error code P0303 - Suzuki Forums: Suzuki Forum Site
Old 08-13-2018, 10:03 AM   #1 (permalink)
sx4 trinidad is on a distinguished road
Unhappy Hi. Error code P0303
Hi All. Thanks for membership.
I have a question, and need some assistance.
Basically, I drive a 2011 SX4 M15A YA11S. Vehicle started losing power and vibrating. Engine Problem light ON.
After Diagnostic scan and resetting, Error code P0303 comes back and does not does not want to go away although I changed all spark plugs, coil packs, and thoroughly service and tested engine at many many mechanics. Is the problem now the Computer and needs changing?
Regards
Shastri
sx4 trinidad is offline   Reply With Quote Quick reply to this message
Old 08-13-2018, 03:00 PM   #2 (permalink)
LMP
LMP's Avatar
P0303: Cylinder 3 Three Misfire
Problem specific to this cylinder only.
spark plug..., coil pack....OK...I would check wiring to coil pack.
Which engine in this one....?..does M15 relates to 1.5 litre engine ?
Old 08-13-2018, 08:27 PM   #3 (permalink)
Default Thanks for the reply LMP
engine is a 1.5 L, gas.
I could try and get the wires checked.
I forgot to mention, also on resetting the error code (about several times), it disappears for about 15 to 20 minutes after which it returns. However prior to returning, the vehicle drives perfect, no vibration and accelerates very well. But when the engine light comes back on for no reason, that is where the problem starts back with vibration and lazy acceleration. The rpm gauge also seems to fluctuate about a value when it should be steady.
As for the wires, I could try and take apart and check, but Is there a test other than a visual I can perform? such as a continuity with a multi-meter? and what size wire should I replace it with if I saw a breakage?
Thanks again
Regards
Shastri
Old 08-14-2018, 08:54 AM   #4 (permalink)
john yayay's Avatar
john yayay is on a distinguished road
Just curious, but how does the computer detect a misfire?
O2 sensor could detect poor/no burn. Knock sensor?
john yayay is offline   Reply With Quote Quick reply to this message
Old 08-14-2018, 12:09 PM   #5 (permalink)
LMP
LMP's Avatar
Originally Posted by john yayay View Post
Just curious, but how does the computer detect a misfire?..
an abnormal voltage at the coil pack primary winding is interpreted as a MISFIRE
Old 09-18-2018, 10:49 PM   #6 (permalink)
aquanaut20's Avatar
actually, misfires are triggered by a discrepancy between the CAM and CRANK signals, you will need a scope to see the digital signals..
Philip
.... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
