Replacing the Rear Wiper Arm: SX4 hatchback - Suzuki Forums: Suzuki Forum Site
Old 07-18-2018, 03:34 PM   #1 (permalink)
bsmy84's Avatar
bsmy84 is on a distinguished road
Default Replacing the Rear Wiper Arm: SX4 hatchback
I've ordered a replacement rear wiper arm for my 2011 SX4 hatchback.
Any suggestions as to how I properly remove the existing arm and install the replacement?
Obviously, I don't want to botch this replacement and damage something in the process.
bsmy84 is offline   Reply With Quote Quick reply to this message
Old 07-18-2018, 06:30 PM   #2 (permalink)
LMP
LMP's Avatar
At first I thought I was to break something..but rotate the blade from the arm past 90 degrees and it will fall off
Old 07-18-2018, 07:40 PM   #3 (permalink)
bsmy84's Avatar
I appreciate your reply, LMP. However, I'm not clear on your directions.
Rotate the arm 90 bending or turning it outward at the joint away from the window as in outward away from the car? ... or rotate the arm clockwise or counterclockwise past 90 along the window plane?
Assuming I get clear on how to do this, does this break the arm that's being replaced? I'd prefer not to break it if possible.
Old 07-18-2018, 11:34 PM   #4 (permalink)
are you replacing the entire wiper arm to the motor? or just the blade at the end of the arm?
Old 07-19-2018, 12:51 AM   #5 (permalink)
bsmy84's Avatar
it's a new arm including a new blade - the whole tamale
Old 07-19-2018, 03:41 AM   #6 (permalink)
ok, fun begins, lift cover on old arm at pivot, should be a nut under it, loosen, do not remove. Lift wiper arm so blade is locked away from the window surface like you do when you clean the windows. The arm is retained on a tapered shaft with little splines. What you need to do is wiggle the base where it goes onto the drive so it comes loose. When it does you will see why i said don't remove the nut, it will either do it real easy, or be a pain.
once its free, remove the nut, replace arm, line up wiper blade in the correct "parked" position, then tighten nut.
Look at the new one, you will see what i mean
https://www.bing.com/videos/search?q...D9B8&FORM=VIRE
while not for the SX4, it gives you the general idea and steps to follow, including him fighting with the second one to get it to come free
Old 07-19-2018, 06:59 AM   #7 (permalink)
LMP
LMP's Avatar
for just the blade...----just lift the arm to about 60 from the window, then rotate the blade an extra 90 in same direction. It will fall off. Real easy. Just done it again this morning ...photos coming.
...???was the arm damaged?....
Old 07-19-2018, 07:12 AM   #8 (permalink)
LMP
LMP's Avatar
www.avigex.ca/sx4/IMG_5200s.jpg
www.avigex.ca/sx4/IMG_5201s.jpg
www.avigex.ca/sx4/IMG_5202s.jpg
Old 07-19-2018, 03:26 PM   #9 (permalink)
bsmy84's Avatar
Thank you, 2013GV.
Old 07-19-2018, 03:29 PM   #10 (permalink)
bsmy84's Avatar
Thank you, LMP for your additional feedback and the photos.
