Non-working OBD? - Suzuki Forums: Suzuki Forum Site
Old 09-07-2017, 01:25 PM   #1 (permalink)
fredhag is on a distinguished road
Default Non-working OBD?
I bought a used '08 SX4 several months ago. It's running great so far, but I haven't ben able to make a connection through OBD. My scanner has worked on every car I've tried, and I made sure it's still working with other cars. I don't have much experience with OBD so I am unsure where I should be focusing looking for bad wiring, etc. Thoughts, please?
fredhag is offline   Reply With Quote Quick reply to this message
Old 09-07-2017, 01:33 PM   #2 (permalink)
What happens when you try to connect, is there an error message, does the reader power on?
How old is your reader, what protocols does it support, were/are the cars it works on older or newer than the SX4?
Old 09-07-2017, 02:02 PM   #3 (permalink)
Thanks for replying. I should have mentioned both of those. The scanner says it first tries OBD II (which is quick) and then it seems to get stuck trying to scan CAN (I'd have to look again, but I think it mentioned briefly there were 2 CAN versions) - it never stops or gives an error. If I need to know ISO/CAN version numbers, I'll need to hunt down the manual. The other cars were older - '98 - '04.
Old 09-07-2017, 02:47 PM   #4 (permalink)
avisitor is on a distinguished road
On some older cars, the pins on the data link connector (DLC) gets spread out
And don't make good connections. So, the scanner may not be making the contacts in the connector
avisitor is offline   Reply With Quote Quick reply to this message
Old 09-08-2017, 07:52 AM   #5 (permalink)
Donewrken's Avatar
Most scanners will list in order the protocol's it is trying when attempting to
make the connection. Does yours list them?
Are you waiting long enough for it to connect?
It should say link error if it cannot connect, may only flash for a 1/2 second
then go to start screen.
It might not have the correct protocol. Yours is listed as OBD_II - KWP2000_Fast_Init.
Take your car to an Autozone for a free scan and ask them what protocol it is using.
If they can connect, then you will know it's your scanner at fault.
Don
I'm here in the USA.
1991 GMC K2500 4WD 454 Xcab
1997 Trans Am LT1 auto
Old 09-14-2017, 07:55 PM   #6 (permalink)
Thanks! Stupid me didn't think of taking it in and checking what they are able to get with a (presumably) much better scanner. This might be just in time because I just got a check engine light as the engine has been running weak and rough after I ran it to the bottom of the tank this week.
