Starter Motor Wont Crank Engine - Suzuki Forums: Suzuki Forum Site
Old 08-19-2017, 01:46 PM   #1 (permalink)
walkerj is on a distinguished road
Default Starter Motor Wont Crank Engine
Starter Motor wont crank the engine. Replaced battery and Starter Motor, both main 12v and switch signal present at starter motor but wont crank the engine. Any suggestion? Thanks.
walkerj is offline   Reply With Quote Quick reply to this message
Old 08-19-2017, 01:59 PM   #2 (permalink)
Is the engine seized?
Try wrenching it over by the crank pulley bolt, turning it clockwise.
Welcome aboard too.
Old 08-19-2017, 02:04 PM   #3 (permalink)
Is it common for the engine to seized? I'll try tomorrow, thanks.
Old 08-19-2017, 02:31 PM   #4 (permalink)
Not common unless internal engine noises developed at the last running moments, or it overheated, was over-revved, or you ran it out of oil.
Even then, you would HEAR a significant clank as the starter engages the flywheel.
Let's hope for an electrical circuit or battery issue.
Old 08-19-2017, 09:49 PM   #5 (permalink)
aquanaut20's Avatar
After rolling engine by hand (not seized verification),
Perform Voltage drop test (battery(+) to main starter stud) , and battery(-) to engine block (ground side) under load.
Check for 12vdc at "S" terminal of starter..
.... Philip
.... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 08-21-2017, 10:01 AM   #6 (permalink)
LMP
LMP's Avatar
Originally Posted by aquanaut20 View Post
....Check for 12vdc at "S" terminal of starter......
UNder load, it will fall maybe a few volts below 12....
but we still do not know if the engine is seized.....or maybe everything is OK now and we have no feedback....
Old 08-21-2017, 12:47 PM   #7 (permalink)
aquanaut20's Avatar
That is why you were advised to roll the engine over by hand, verify seized or not..
Voltage test will be invalid, unless free to roll..
... Philip
.... Philip
Old 08-21-2017, 12:54 PM   #8 (permalink)
THANKS to all, engine started after turning the crank by the crank pulley bolt clockwise. I'm still confused at to the engine seized. I'm not sure if their is any relation but everything started by my son connection the positive cable terminal of the car to the battery making contact to the to car metal with the wrench. THANKS again to everyone for the suggestions.
Old 08-21-2017, 12:58 PM   #9 (permalink)
LMP
LMP's Avatar
feedback received. Thanks
Old 08-21-2017, 01:08 PM   #10 (permalink)
Engine seizure isn't an off and on occurrence with the exception of very unusual circumstances. SOMETIMES an engine overheat or hydro-lock situation can momentarily cause engine locking.
I'm saying this as I think that you have an intermittent electrical problem, particularly in light of this recent shorting of the battery terminal. I suspect that the engine started by chance, in other words.
Close inspection of the battery, connections to include starter and ground leads are in order IMO. The starter proper could also be the culprit.
When it DID start, was there any foreign engine noise or exhaust smoke? Are the oil and coolant levels proper and lack any sort of discoloring?
