2008 sx4 engine light - P0722 - Suzuki Forums: Suzuki Forum Site
Old 10-30-2016, 09:45 PM   #1 (permalink)
EricCartmen is on a distinguished road
Default 2008 sx4 engine light - P0722
Hi guys, I have 2008 sx4 and just got check engine light on - P0722. Something wrong with a speed sensor. Where is the sensor located? Thanks.
EricCartmen is offline   Reply With Quote Quick reply to this message
Old 10-31-2016, 05:13 PM   #2 (permalink)
Darrell.'s Avatar
Welcome to the forum. I've based my info on the 2L but depending on country you have a few engine sizes to chose from. Looking in the workshop manual this code was shown for the automatic transmission so I'd like to think this is correct.
2005 Grand Vitara MT 1600se.
Old 10-31-2016, 05:42 PM   #3 (permalink)
gmasi08 is on a distinguished road
I just got my reading on that and..You may need a new wheel bearing. The magnets in the bearing may be bad which gives you a bad reading. The magnets help read your RPM's. Your mechanic can find out which bearing is bad. Have him check out your ABS sensors as well. Picture example below:
202SS Bearing Deep Groove 202SS
This needs to be done by a professional mechanic. Then when he is done have him reset your codes to clear the engine light.
Suzuki 2008 SX4 Sport Sedan, Pioneer Audio, 157,000 miles
gmasi08 is offline   Reply With Quote Quick reply to this message
Old 10-31-2016, 05:47 PM   #4 (permalink)
Darrell.'s Avatar
I'm confused, P0722 is a transmission code .
Old 10-31-2016, 06:58 PM   #5 (permalink)
I don't remember my code but the description on his computer read "speed sensor"
and it was the bearing needed to be replaced. Check that first instead of doing an the entire overhaul on the electronic shift system.
Old 10-31-2016, 07:25 PM   #6 (permalink)
Darrell.'s Avatar
The ones in the wheel bearings are for the ABS.
Old 10-31-2016, 07:29 PM   #7 (permalink)
Darrell.'s Avatar
No overhaul, at worst 1 bolt holding in sensor.
Old 10-31-2016, 10:06 PM   #8 (permalink)
aquanaut20's Avatar
The offending sensor is in the transmission, check for degradation of signal with a DSO (scope), the sensor some timed lifts from its seat with corrosion, try removing and cleaning the bedding surface..
A MM is not fast enough to see a proper signal..
... Philip
.... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 11-01-2016, 11:28 AM   #9 (permalink)
Thank you all for answers! Its very helpful.
Old 11-01-2016, 06:40 PM   #10 (permalink)
I have automatic transmission and it doesn't work. When I put tranny to D mode the car just stays, even if I give some rev to engine... I still have P0722 issue. Does those 2 issues related to each other?
