ecu / downstream oxygen sensor problem - Suzuki Forums: Suzuki Forum Site
Old 05-04-2016, 11:57 AM   #1 (permalink)
zabicki is on a distinguished road
Default ecu / downstream oxygen sensor problem
Hi there,
I have a problem with the downstream oxygen sensor and the ecu
I got check engine light with p0138 error code.
I scanned the scar and noticed that the voltage on the downstream oxygen sensor is constant 1.3 volts. The sensor was removed from the car and tested with a torch and a multi-meter Technically seems to work ok.
However there is something weird. I scanned the car without the sensor connected and the voltage stays the same - 1.3 volts on the ecu.
I also scanned the voltage on the o2 plug coming to the ecu.
I got 12v on the heater wires and 4.35 volts coming down to the oxygen sensor (from ecu) (positive and ground wires).
Can you please help me to diagnose what's going on ?
zabicki is offline   Reply With Quote Quick reply to this message
Old 05-04-2016, 02:22 PM   #2 (permalink)
aquanaut20's Avatar
Check for shorted wires, common to hot pipes, and frame scuffing..
... Philip
.... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 05-04-2016, 03:52 PM   #3 (permalink)
LMP
LMP's Avatar
Originally Posted by zabicki View Post
...I got 12v on the heater wires and 4.35 volts coming down to the oxygen sensor (from ecu) ....
Both voltages OK. 4.35 open Volts from ECU is normal.
Welcome to the forum. In order to know you more, please fill up your profile, where are you, car type, year, AWD?..transmisison..etc. ...
Old 05-04-2016, 04:51 PM   #4 (permalink)
Oh you got me 2008 SX4 AWD automatic. Regarding the voltage - why my android scanner shows 1.3V for that o2 sensor? Shouldn't be 0V when disconnected?
Technically the scanner shows 1.3v either connected or disconnected and pops up with p0138 code...
Old 05-04-2016, 05:48 PM   #5 (permalink)
aquanaut20's Avatar
http://www.obd-codes.com/p0138
.... Philip
Old 05-04-2016, 05:59 PM   #6 (permalink)
I know what that code means. The problem is that I see that code even though the sensor is disconnected...
Old 05-04-2016, 06:39 PM   #7 (permalink)
unless there is an open circuit and 1.3v means that the sensor is broken.
Is there anyone how could check that on their car? like unplugging the downstream sensor and checking what voltage appears one the scanner .. I know it's a lot to ask for.
Old 05-04-2016, 07:20 PM   #8 (permalink)
aquanaut20's Avatar
Why dont you verify the circuit?
Unplug at ECU and check for voltage drop/ground/shorts.. If the circuit proves viable.. all is left is the sensor..
As an after though, what are the Fuel trims and the B1S1...
... Philip
.... Philip
Old 05-04-2016, 10:46 PM   #9 (permalink)
How can I check the wires for shorts. You mean the hot (positive) one with both heater wires and the ground (negative) with the hot (positive) right?
I suspect that the wires are ok - already getting 12v on the heater wires and ~5v on the hot and ground (negative) wires. if there was a broken wire I couldn't get the right voltage on the plug coming from the ecu
The A/F sensor is brand new.
Old 05-05-2016, 01:16 AM   #10 (permalink)
aquanaut20's Avatar
I suggested in post 8, do you not understand how to verify the circuits, or do you wish to keep guessing?
If you unplug from ECU (power OFF)they should all be open, no shorts to ground, when tested from sensor plug.
Baring that, employ an auto electrician...
... Philip
.... Philip
