Turning Signals turn on very slowly - Suzuki Forums: Suzuki Forum Site
Ľ Wheel & Tire Center
Like Tree2Likes
Old 08-09-2019, 09:45 PM   #1 (permalink)
rasmeidirtrider is on a distinguished road
Default Turning Signals turn on very slowly
The turning signals seems to turn on very slowly. Any ideas??
'96 (07/95) US imported Sidekick Sport, 16V, 1.8L, 4spd auto, 4x4, A/C, ABS, 100K miles, VIN: JS3TD21V6T4101985, bone stock, except 215/70R16 Tires.
rasmeidirtrider is online now   Reply With Quote Quick reply to this message
Old 08-09-2019, 09:58 PM   #2 (permalink)
describe what its doing, same for left and right?
Quite possibly a flasher relay starting to fail but more symptoms will help diagnosis
2008 Swift M15A
Old 08-09-2019, 11:51 PM   #3 (permalink)
The left, the right and the hazard one.
Old 08-10-2019, 12:15 AM   #4 (permalink)
Probably this one.
https://www.rockauto.com/en/catalog/...nal+relay,3904
The mech says it can be repaired!
Old 08-10-2019, 12:45 AM   #5 (permalink)
you got to be kidding, they won't repair it, go buy a universal flasher relay and plug it in yourself.
2008 Swift M15A
Old 08-10-2019, 04:21 AM   #6 (permalink)
Section Moderator
You may want to check the ground for the turn relay as well. I donít know the location in the Sport - in the 1.6 itís just above the fuse panel under the dash.
'61 NSU Quickly - 150mpg
Old 08-10-2019, 04:24 PM   #7 (permalink)
Donewrken's Avatar
A bad bulb will cause slow flashing also.
What are the odds you will have a bad bulb on two sides at the same time?
A zillion to one, but I have seen it.
I found a front bulb and a rear bulb diferent sides bad bulbs.
Just replace them all to save yourself from needing to do it again shortly.
Yes, a generic flasher.
It would be a good time to go LED's, more light is a good thing.
If you do remember to do the center brake, dash lights, interior overhead and backup lights plus a flasher for LED's.
Did both of mine and the truck, I like em!
Don
jimdoogie12 likes this.
I'm here in the USA.
1991 GMC K2500 4WD 454 Xcab
1997 Trans Am LT1 auto
Old 08-10-2019, 07:48 PM   #8 (permalink)
Manufacturers safety specs mandated that a blown lamp shall cause a fast flash, post about 1990. Most countries adopted this around this date as well.
If its an ancient bi metallic unit then a blown lamp will cause a slow flash, but as far as I know, these units had the "internally compensated" version that went fast if a lamp blew.
Bex likes this.
2008 Swift M15A
Old 08-15-2019, 08:44 PM   #9 (permalink)
likembikem is on a distinguished road
Default Slow turnsignals
They still work, just slow. So I would check the connections, make sure tight and clean. Check grounds. Check what the battery voltage is and if the charging system is putting out the correct voltage.
likembikem is offline   Reply With Quote Quick reply to this message
Old 08-16-2019, 01:37 AM   #10 (permalink)
the blinker relays do die, they are a mechanical device and have a finite life, its got to be getting towards 20-25 years old
2008 Swift M15A
