1997 geo tracker smokes excessively when first started - Suzuki Forums: Suzuki Forum Site
Like Tree1Likes
  • 1 Post By 2013GV
Old 08-03-2019, 07:58 PM   #1 (permalink)
Dan97GeoTracker's Avatar
Dan97GeoTracker is on a distinguished road
Default 1997 geo tracker smokes excessively when first started
Hi,
When I start my tracker I get a cloud of smoke. Blueish like oil burning. If it sits for a week or more it is really a cloud. It also used to stink before I replaced the catalytic converter. As a side note I don't seem to have a pcv valve. There is a brass elbow with a baffle plate in it the is plugged into the valve cover with a hose to the intake. Is this normal?
Dan97GeoTracker is offline   Reply With Quote Quick reply to this message
Old 08-03-2019, 11:49 PM   #2 (permalink)
Originally Posted by Dan97GeoTracker View Post
Hi,
no, it should have a PCV valve usually. What year, motor and trans?
2008 Swift M15A
Old 08-04-2019, 08:10 AM   #3 (permalink)
ranger88den's Avatar
Photo is of my '97 Tracker engine compartment. You can barely see the PCV valve & grommet at the valve cover location (red arrow).
https://postimg.cc/ygTvTMPM
1994 Geo Tracker, 2 dr convertible, 1.6, 8v, 5 spd manual, 4wd
RUST NEVER SLEEPS IN THE RUSTBELT!
Old 08-04-2019, 08:04 PM   #4 (permalink)
1997 1.6L 4wd auto trans. I see Delco PCV valves that are a straight outlet. I have a custom hose with a tight 90 bend that wouldn't fit the outlet and if I a bent a hose it would be a very tight 180. Can't find an original diagram.
Old 08-05-2019, 04:27 AM   #5 (permalink)
Section Moderator
Maybe upload a photo of your setup.
'61 NSU Quickly - 150mpg
Old 08-05-2019, 09:12 AM   #6 (permalink)
https://postimg.cc/R60hYBTw
This is how it should be; emissions hose with gentle bends, PCV valve & grommet.
Old 08-05-2019, 08:52 PM   #7 (permalink)
Hey Ranger,
That clears things up. I have a plastic cover over all of that area and hadn't seen it. You have a rag/towel stuffed into the elbow that I was thinking was where the PCV valve should have been.
That said if the PCV valve is stuck or bad would that cause all the smoke at startup?
Dan
Old 08-06-2019, 12:47 AM   #8 (permalink)
Dan
it certainly won't be helping matters. if its stuck open all the oil and gunge gets sucked straight into the inlet and burnt. pull the hose at the inlet manifold end, if its oily, check the PCV and clean the pipe.
It could be valve stem seals, but look at the easy to get to and cheap repair / maintenance stuff first.
jimdoogie12 likes this.
2008 Swift M15A
Old 08-06-2019, 06:27 AM   #9 (permalink)
" You have a rag/towel stuffed into the elbow that I was thinking was where the PCV valve should have been."
Yeah, the engine is on a stand for future use. I plugged/covered the holes with whatever was handy.
