Ball Bearing in Oil - Suzuki Forums: Suzuki Forum Site
Old 05-25-2019, 12:54 PM   #1 (permalink)
Bovadees is on a distinguished road
Exclamation Ball Bearing in Oil
Any reason I would find ball bearings in the oil of my 8V G16 when I drained it?
1992 US 3sp 4WD Geo Tracker
Bovadees is offline   Reply With Quote Quick reply to this message
Old 05-25-2019, 06:34 PM   #2 (permalink)
I can't think of any place inside a G16 that uses ball bearings...
Old 05-25-2019, 07:13 PM   #3 (permalink)
mtptwo is on a distinguished road
Nor I. Can you post dimensions of the mysterious little orbs?
mtptwo is offline   Reply With Quote Quick reply to this message
Old 05-25-2019, 07:56 PM   #4 (permalink)
about the only one i can think of is the pressure relief valve in the oil pump. everything else is shell or bush type
2008 Swift M15A
Old 05-25-2019, 08:31 PM   #5 (permalink)
I was thinking the same thing. Thoughts of PCV and brake booster check valve guts and even a wildly destroyed water pump shaft assembly should it share a lubricating oil passageway.
Shrapnel of this type will (I think) always be a mystery as to origin.
Who knows for sure. An as-built engine assembly room mishap may account for this since dormant sitting foreign object.
Or we have a saboteur!
Old 05-27-2019, 01:34 PM   #6 (permalink)
0000.186mm
1992 G16 8V 4WD Geo Tracker
1998 G16 16V Suzuki Sidekick
Old 05-27-2019, 02:05 PM   #7 (permalink)
0.186 mm? thats tiny. Those aren't ball bearings at that size, at least from nothing fitted to the engine that I can think of.
You are saying theres small round shiny bits in the oil when you drained it, are they actually ball bearings? or metallic particles that look like ball bearings? can you post a pic please.
2008 Swift M15A
Old 05-27-2019, 02:17 PM   #8 (permalink)
Unless I'm mistaken....
0.186 millimeter ='s 0.00732 inch
Less than the thickness of a sheet of heavy paper.
Something in your reporting is amiss.
Old 05-30-2019, 11:53 PM   #9 (permalink)
Default I really should wear my glasses...
You are all correct of course it should have been 4.68mm.
Old 05-31-2019, 05:22 AM   #10 (permalink)
0.184" diameter then. OK I'll buy that.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ball bearing rattle on wide open throttle OldEmmGee 3G (2006-2014) Vitara & Grand Vitara 7 02-12-2015 11:23 AM
Mystery Ball bearing? Richard123vmt Suzuki Swift and Geo Metro Forum 1 03-09-2010 08:39 PM
Need Advice - Wheel bearing and ball joints... entities Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 11 12-17-2009 09:43 PM
Replacing roller bearing with the cassette bearing KeJaTh Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 8 11-19-2009 04:08 PM
Wheel bearing assmebly, Control arms ball joint silver Suzuki Esteem & Baleno Forum 0 06-04-2009 07:56 PM
