Blower Switch Removal - Suzuki Forums: Suzuki Forum Site
Ľ Wheel & Tire Center
Old 02-27-2019, 11:47 PM   #1 (permalink)
Olddeadmiko's Avatar
Olddeadmiko is on a distinguished road
Default Blower Switch Removal
Hi! I’m new to this forum and to mechanic work. I have a 1998 Chevy Tracker with a bad blower switch. I have removed all of the cables from the heater control unit/case, but I can’t figure out how to remove cables from old switch. I don’t want to break anything. Do I use a screwdriver to pry them out? I don’t see any tabs or anything to help with the process. I have included a picture of the cable.
Blower Switch Removal-890b496e-25b3-4118-935c-d67d6b5c2870_1551332639644.jpg
Olddeadmiko is offline   Reply With Quote Quick reply to this message
Old 02-28-2019, 07:59 AM   #2 (permalink)
ranger88den's Avatar
You'll have to get something thin & strong to insert between the "claws", of the retainer clip, and the plastic HVAC control housing, on both sides, while levering the cable away from the housing. A 2nd hand is helpful. See the clip in the photo.
https://postimg.cc/5QWJxBXz
1994 Geo Tracker, 2 dr convertible, 1.6, 8v, 5 spd manual, 4wd
RUST NEVER SLEEPS IN THE RUSTBELT!
Old 08-03-2019, 04:42 PM   #3 (permalink)
So I know that you stated a small thin strong tool. Any suggestions of what that would be? I have small thin screwdrivers.
Old 08-03-2019, 04:44 PM   #4 (permalink)
And do I wedge the tool between the wire and plastic blower from underneath and pry?
Old 08-04-2019, 10:55 AM   #5 (permalink)
fuzzy1's Avatar
Wait, stop!! Is the trouble you are having with the blower fan switch, or the vent selector?? If it is the fan switch, you don't need to remove the selector cables... unless you absolutely have to get the whole unit out. The switch itself is integrated, using a clamshell type 'cap' on top of the whole switch/selector unit. The switch components can be accessed with the cables still attached. Be aware, there are small springs & a ball bearing under the 'cap' so if you need to open it up, do so carefully, so you don't lose those parts. I've repaired the switch with the whole unit in place... It's a tight area, but there is enough room to access the switch.
'97 Sport 1" Spacer lift, 225/75/16 Cooper AT's
'96 Tracker 1.6l 16v 4x4 2dr 3spd auto 85k 1.5" OME lift - 235/75r15 BFG AT Ko's on 15x7 Ion Alloys: Sold
fuzzy1 is online now   Reply With Quote Quick reply to this message
Old 08-04-2019, 11:50 PM   #6 (permalink)
The whole switch is bad unfortunately. I have the replacement part but can't get the old unit out.
Old 08-05-2019, 01:39 AM   #7 (permalink)
Maybe I'm going about it the wrong way. Do I need to remove blower unit and cables all together? I was trying to disconnect the cables at unit and leave them in the dash.
Old 08-05-2019, 04:38 AM   #8 (permalink)
Section Moderator
If you are dealing with the actual switch, rather than the levers, you donít have to remove cables. Read this:
https://www.suzuki-forums.com/suzuki...-not-work.html
'61 NSU Quickly - 150mpg
Old 08-05-2019, 04:48 AM   #9 (permalink)
I was aware of this fix, but I want to replace the switch and then zip tie it for the future before I reassemble the bezel. My blower switch is broken in this exact area but is beyond this fix. I really just need to know how to get the hvac cables to release from switch.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Blower switch extra wire?? Texas95Tracker4x4 Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 4 11-13-2011 08:17 AM
1993 sidekick blower switch Part number 74460-64A0 Texas95Tracker4x4 Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 7 11-06-2011 07:12 AM
Climate Control Blower Switch???? tjosh97 Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 13 07-18-2010 08:47 PM
A/C Blower/switch/fuse? Help! PinkLady73 1G (2001-2006) XL-7 1 03-31-2009 10:06 PM
96 Track Blower Motor Switch/HVAC Cables the flying scotsman Suzuki Sidekick, Escudo, Vitara, Geo, X-90 & Tracker Forum (1989-1998) 1 12-14-2008 01:58 PM
