1996 Geo Tracker LSI Blowing FI fuse and now won't start. - Page 3 - Suzuki Forums: Suzuki Forum Site
Old 06-24-2015, 01:40 PM   #21 (permalink)
Section Moderator
No, they should not be getting quite warm - there is only a small amount of wattage running through them. It would appear that you have an intermittent wiring problem somewhere, which is causing your issue. You need to do some diagnostic testing - testing battery voltage, the fuses, electrical circuits, etc. I would venture to say that, while your car is running now, your problem will show up again.
'61 NSU Quickly - 150mpg
Old 06-24-2015, 03:37 PM   #22 (permalink)
umiami80's Avatar
umiami80 is on a distinguished road
Ok I gotta find that short. But if everything is running fine now, is there even a way to test for it?
umiami80 is offline   Reply With Quote Quick reply to this message
Old 06-24-2015, 03:38 PM   #23 (permalink)
umiami80's Avatar
Battery voltage is over 12, alternator is like 14.4, both are brand new. I think I have a short in the wire loom somewhere. I'll check at the fire wall first.
Old 06-29-2015, 08:21 AM   #24 (permalink)
umiami80's Avatar
Been driving it every day? Sometimes well over 100 miles a day. Cannot replicate the issue.
Strange.
That said I believe it was in the injector wire harness as was last time we shook it the fuses stopped blowing.
Old 06-29-2015, 01:31 PM   #25 (permalink)
m000035 is on a distinguished road
Originally Posted by umiami80 View Post
... That said I believe it was in the injector wire harness as was last time we shook it the fuses stopped blowing.
I doubt it is "fixed."
Most likely you have a bare wire somewhere in the harness and you just moved it from what it was shorting to. It could easily move back to the original position.
I wouldn't drive it any farther than I wanted to walk until you find it.
You can remove the harness and take it inside. strip it down, inspect, fix if needed and re-wrap. Hopefully you find the smoking gun. (The bare wire.)
Mike
-- Upstate New York
'96 Sport, 1.8L, 4sp
'94 JLX Kick, 16v, 4sp
'89 JLX Kick 8v, 2 door tintop 4x4 (Basketcase/Project)
'94 8v, 2 door tintop 4x4 5 speed Tracker
Plus a '08 Malibu named "Boo."
-- left in Oregon
'93 8v, 2 door tintop 4x4 5 speed Tracker
'98 16v, 2 door 2wd, soft top 5 speed Tracker
'92 JX, 16v, 4sp parts rig
'94 8v, 2wd, soft top (Project Parts donor)To follow my Projects see: http://m000035.blogspot.com/
m000035 is offline   Reply With Quote Quick reply to this message
Old 06-29-2015, 02:57 PM   #26 (permalink)
umiami80's Avatar
I agree with your assessment. At least now I know how to make it stop failing in a pinch. I also keep a ton of fuses.
Regards.
Old 06-29-2015, 03:47 PM   #27 (permalink)
ranger88den's Avatar
Found this in the harness when transplanting a 16v JDM engine in my '95 Tracker.
http://s1301.photobucket.com/user/ra...ml?sort=3&o=49
Old 06-29-2015, 09:29 PM   #28 (permalink)
umiami80's Avatar
DSCN11441_zpsmwzbr6ru.jpg Photo by ranger88den | Photobucket
WOWOWOWOW That would do it?
Where was that problem area?
New Tracker Baby!!!
https://www.suzuki-forums.com/image-v...back-baby.html
1998 Chevy Tracker 5-Speed 4x4
Old 06-30-2015, 06:18 AM   #29 (permalink)
Vibration/rubbing/attrition.
Main harness, right side of engine.
1994 Geo Tracker, 2 dr convertible, 1.6, 8v, 5 spd manual, 4wd
RUST NEVER SLEEPS IN THE RUSTBELT!
Old 08-07-2019, 12:15 PM   #30 (permalink)
aaleonard5042 is on a distinguished road
Originally Posted by Bex View Post
x2. This is certainly the easy way to do it.
Regarding J Benoit, I have found 3 of his ECU diagrams on the internet, one for OBD1 TBI, OBD1 MPI and OBD2. I'll upload them to a new thread - maybe it would be a good idea to make them into a sticky. Kudos to this guy, whoever he is - they are truly incredibly excellent....
where can i find the one for tbi?
aaleonard5042 is offline   Reply With Quote Quick reply to this message
