Soft top trim solutions? 95 Tracker - Page 2 - Suzuki Forums: Suzuki Forum Site
Old 11-06-2014, 12:27 PM   #11 (permalink)
ASX2006 is on a distinguished road
Hi. I'm still debating on what to do about my '97 Gen 2 Top. The options that I am thinking about are: 1. Going to a Gen 1 top. Has anyone made a parts list or write up in it? 2. Doing what Gigafex has done. As well as 3D print the retainer brackets (just need measurements on a complete bracket). 3. Make a hybrid out of the Gen 2 top and add snap buttons to the top.
What do you guys think?
Click image for larger version
ID:	40169Click image for larger version
ID:	40177Click image for larger version
ASX2006 is offline   Reply With Quote Quick reply to this message
Old 11-06-2014, 02:20 PM   #12 (permalink)
ranger88den's Avatar
Attachment 40169Attachment 40177Attachment 40185
If retrofitting:
https://www.suzuki-forums.com/suzuki-...r-tracker.html
1994 Geo Tracker, 2 dr convertible, 1.6, 8v, 5 spd manual, 4wd
RUST NEVER SLEEPS IN THE RUSTBELT!
Old 11-06-2014, 03:25 PM   #13 (permalink)
colonelhogan44's Avatar
colonelhogan44 is on a distinguished road
Is that piece you drew up the only one you need? it's fairly small and could probably be easily printed with a few slight modification.
1993 Tracker 4x4, 2 door, 8v, 3 sp auto, 135k - 24.3 mpg
1996 Tracker 4x4, 2 door, 16v, 3 sp auto, 107k - 25.9 mpg
2005 Volvo S40 T5 AWD, 69K - 26.0 mpg
1987 Mercedes-Benz 300D turbodiesel, 4 sp auto, 152k - 27.9 mpg
WARNING: this post contains thoughts that may at any point be discovered by the state of California to cause cancer.
colonelhogan44 is offline   Reply With Quote Quick reply to this message
Old 11-06-2014, 04:50 PM   #14 (permalink)
That piece and the opposite side. The top half of it was broken off by the P.O. Once I figure out the dimensions I am going to 3D print it and test it out. I got this out of a different post. Going try this shape. This one is metal. The one I have is plastic. Click image for larger version
Old 11-06-2014, 05:55 PM   #15 (permalink)
Gigafex's Avatar
Gigafex is on a distinguished road
yeah I've been missing the "latch clip" out of mine since i bought it but the tail gate holds the bar in so meh not to worried
1995 tracker 4x4 16v converted 5 spd
2002 vw jetta tdi 54mpg
1973 vw bug 1600 dual port freshly restored spring 2012
Gigafex is offline   Reply With Quote Quick reply to this message
Old 11-06-2014, 06:27 PM   #16 (permalink)
Section Moderator
Generation 1 has different hardware (front bow attaches with sliding clips and not snaps, side windows, attachment at tailgate, etc.)
'61 NSU Quickly - 150mpg
Old 01-06-2015, 03:15 AM   #17 (permalink)
Here's my 3D printed test part.
As it printed
Cleaned up
ID:	42986Click image for larger version
Sprayed with rubber undercoat
Trimmed and installed.
ID:	43034Click image for larger version
I guess some of the dimensions and was wrong in a few spots. I'm going to update the design and give it another go.
Will keep posting here for now.
Planning on making a metal version and some with mixed materials.
Old 01-06-2015, 11:21 AM   #18 (permalink)
Very nice!
If you're in a hot area, know that that part will quickly deform if it's PLA on a hot sunny day.
Old 01-16-2015, 06:43 PM   #19 (permalink)
kirk is on a distinguished road
Default Why Switch from a gen1 top to a gen2...
Well, I just finished converting our Canadian 1992 Pontiac Asuna two door over to the gen 2 style top.
Why? I have a back problem that meant I needed two canes and a walker to get around. I could not lift anything, even a plate full of food hurt. That left it to my wife to wrestle my walker in and out of the back through the passenger door (the rear window zipper was frozen solid), and it was hard for her to do that, being that both of us are over 70.
The gen 2 top allows her to open the tailgate and slide my walker into the back without unzipping the rear window. There's even room for a wheel chair (the rear seats are removed), if it comes to that.
And yes, it was a picky, finicky job to lay out all the clips/fasteners that I stripped off a wrecked '96, but everything lined up and nothing leaks.
2000 Vitara 2.0l four, 4 speed auto w/od, P235 16r, 2 door, 4x4, auto hubs
kirk is offline   Reply With Quote Quick reply to this message
Old 01-17-2015, 06:21 AM   #20 (permalink)
Section Moderator
The generation 1 top has the fiberglass rod that snaps into the brackets on the tailgate. Could you not have just unsnapped that rod, and then opened the tailgate without unzipping the window???
