distributor rotor position - Suzuki Forums: Suzuki Forum Site
Old 03-14-2014, 09:49 PM   #1 (permalink)
rschoner is on a distinguished road
Default distributor rotor position
Hi,
Replacing the rotor in a 1995 Geo Tracker. The rotor can be placed in any of three positions. Does it matter how it goes? I'm used to rotors that can only be placed in one position. Thanks
Bob
rschoner is offline   Reply With Quote Quick reply to this message
Old 03-15-2014, 01:18 AM   #2 (permalink)
aquanaut20's Avatar
That is indicative that you have a cheap Chinese clone, it is no good...
Find an OEM rotor, it will only fit one way....
...... Philip
.... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 03-15-2014, 05:21 AM   #3 (permalink)
Section Moderator
x2. The proper rotors will only fit on one way, and that's what you should use.
'61 NSU Quickly - 150mpg
Old 03-15-2014, 06:15 AM   #4 (permalink)
Default Dist Rotor Position//More Info
The rotor was on the Tracker but was removed because of a transmission r and r. I took the dist cap and rotor off so that I could get a block of wood between the dist and the firewall as recommended by the manual.
The rotor has three flats on it. The dist shaft has three flats on it. The flats are spaced equally so the rotor can go on in three different positions. Chinese copy or not, any rotor would have to have the three flats so it could fit the shaft. I guess I have to follow the steps to take if "Distributor position is lost".
Bob
Old 03-15-2014, 06:38 AM   #5 (permalink)
Default Rotor and Dist Pictures
Click image for larger version
Name:	Tracker Distributor2.jpg
Name:	Tracker Rotor.jpg
ID:	30770If I did this right there should pictures that I got off of EBay showing the dist and the rotor. Arrows indicate the flats that I was talking about.
Old 03-15-2014, 01:26 PM   #6 (permalink)
Section Moderator
I believe you will notice, if you carefully look at the distributor, while there are 3 'flats' on it, two of them are longer than the third. On the correct FSM rotor, the short flat of the rotor must adhere to the short flat of the distributor.
Old 03-15-2014, 02:48 PM   #7 (permalink)
Guest
The simplest way to get it right is to turn the motor over until its at TDC on number one cylinder and then check where the number one spark plug lead is on the distributor cap.
Old 03-15-2014, 03:58 PM   #8 (permalink)
You're right. I have an old core distributor and can see the different sizes of the "flats". I probably would not be able to see that with the dist in the car. I also had an older rotor and it only goes on one way. I put the older rotor on the dist in the car and found out which way it pointed. I then turned the crank to TDC and it pointed to the Number 1 plug wire so I know I got it right.
Time to fill the fluids, install the battery and see how it goes.
Thanks for the help.
