Clutch Fluid? - Suzuki Forums: Suzuki Forum Site
LinkBack Thread Tools
Old 03-27-2012, 04:31 PM
cca105983 is on a distinguished road
Default Clutch Fluid?
Hey Everybody! So I was browsing around the internet and found myself reading several articles that claim that one with a new car w/ a manual tranny should watch their clutch fluid color because if the car is driven in a sporty manner, the metal dust worn off the clutch mixes with the fluid and if not cleaned, it could cause sticking due to accumulation of this dust. As soon as i saw this i figured my clutch fluid is probably black by now haha.. Here is the thing though, the latter being true or not, where is the clutch fluid?! Does anybody know where it is?? The only thing that came to mind was that maybe the clutch uses the brake dot3 fluid too? But if so why doesn't it label?
cca105983 is offline   Quick reply to this message
Old 06-04-2012, 09:27 AM
hei223 is on a distinguished road
Default Clutch pedal slave ????
I think the fluid you question is for a device which is called a clutch pedal slave.
I owned a Plymouth Saporro that was a MT, I seem to remember it had a slave. A slave is a hydraluic cylinder which aids in smoothly engaging the clutch when pressing the pedal while shifting gears. It is within the pedal to clutch linkage, usually under the vehicle. Your vehicle may also have a clutch master cylinder. It would be connected to the slave.
There isn't any fluid in the bell housing where the clutch is located. If grease or oil gets on the fiber disk of the clutch it will cause slipping. In other words there isn't any fluid within the clutch/pressure plate housing. Only a A/T has fluid in it.
hei223 is offline   Quick reply to this message
Old 06-05-2012, 10:07 AM
XL7Limited's Avatar
Impossible. The hydraulic clutch system is a closed system, it would impossible for clutch dust to get into it.
XL7Limited is offline   Quick reply to this message
