Oil consumption - Suzuki Forums: Suzuki Forum Site
Old 07-12-2019, 07:53 AM   #1 (permalink)
modessef1 is on a distinguished road
Default Oil consumption
Hello,
I drive on the full syntetic 5W30 oil in my Kizu 2.4 AWD CVT as provided in the manual for my region. I drove the route ~ 800km which I beat quite dynamically. Long sections 170 km/h and for a short time 200 km/h.
Before the route I had the oil level full, and after the route I have a lot below the minimum. It was maybe 1cm on the bayonet.
Do your kizashi "drink" the oil when driving fast and this is normal for this model or is it likely that the engine will be completely refurbished?
modessef1 is offline   Reply With Quote Quick reply to this message
Old 07-12-2019, 02:01 PM   #2 (permalink)
I added 1 liter of oil and I'm half between min and full..
Old 07-12-2019, 04:30 PM   #3 (permalink)
What was the level before you started this trip?
when was the oil last changed?
when was the car last driven like this?
do you do a lot of slow speed stop start driving?
its common for cars driven around town then taken out onto the open road to do this as condensation build up in the oil and "hot" driving like you have done drives the moisture out of the oil. Your consumption does seem excessive tho. Is it still using oil? and fill it to the full mark when cold, not when hot.
Old mechanics trick, start cold engine, idle for 30 seconds, shut off and check level, should be just below full mark. If checked cold and not run overnight, level should be just over the full mark. Oil is also used as a coolant, and less oil means less cooling, so maintaining the correct level is always advisable.
Old 07-13-2019, 08:09 AM   #4 (permalink)
I bought this car 1.5 months ago. The owner said he changed the oil in February, the oil on the dipstick looked fresh, so that would more or less agree.
I rode earlier fast (~ 160km / h) but max for 50km
I live in a big city, so yes.
Yes, I have to buy more oil and fill it with full one. Of course, on a cold engine. I go calmly and see if it starts to wear off.
ok, i will do this test
I use Shell oil because the previous owner used it. In my previous car I used Fuchs Titan Pro Race. I wonder whether to change here for the same oil. As a user with a lot of experience on the forum, do you know what oil is most often chosen by kizashi owners here and the most recommended?
Old 07-14-2019, 02:39 AM   #5 (permalink)
before the trip he was on full
I bought it recently but the owner speaks in February. After the purchase I checked, he was full and had a nice color. Far from black, so it seems to be true
Yes, I've had it for 1.5 months and I've driven it fast but not that much. Before this trip I probably did not exceed 170km / h and I traveled so short sections, about 20km. And besides, it's a lot of traffic in the city, meaning traffic lights
Quite a lot because I live in a big city
Old 07-14-2019, 02:56 AM   #6 (permalink)
yesterday I was pouring in full oil and passed ~ 100km very calmly. turning it on only when overtaking. Today I will see if the level has dropped.
The ends of the exhaust look terrific. As if he literally spilled oil:
https://drive.google.com/open?id=1-N...2fcdRpLuGq4uN5
https://drive.google.com/open?id=1-Q...FnRNKzZ8U0CeOZ
I checked the spark plugins and they look pretty nice. They are not oiled.
https://drive.google.com/open?id=1-P...o0_7_rKmcvJjOH
https://drive.google.com/open?id=1-S...Hz3y-barPpVMuY
https://drive.google.com/open?id=1-T...qRU2XK3oa2yeux
https://drive.google.com/open?id=1-b...pwyK-wjcIhUCAX
Old 07-14-2019, 03:23 AM   #7 (permalink)
the plugs look great, the exhaust, not so much.
Keep an eye on the consumption.
Old 07-14-2019, 04:02 AM   #8 (permalink)
I wonder what may be wrong that the exhale looks like this.
I see two options:
-valve gasket
-rings
Old 07-14-2019, 04:21 AM   #9 (permalink)
I see two options:
-valve gasket
-rings
stuck / clogged / faulty PCV valve would be my first check, after that its Valve train, head gasket, rings etc.
check and clean PCV valve, should rattle if you shake it.
Monitor the consumption, if its only using it at high speed its quite possible its a PCV valve.
Old 07-14-2019, 04:47 AM   #10 (permalink)
Do you have image/instruction where I can find it how check it?
