need major help on my 1988 Suzuki Samurai - Suzuki Forums: Suzuki Forum Site
Old 12-18-2013, 06:59 PM   #1 (permalink)
roblee is on a distinguished road
Default need major help on my 1988 Suzuki Samurai
Guys I need help this is my only vehicle. My truck yesterday
just will not crank. I noticed no gas getting to my Carb so I have replaced the fuel filter no luck. So I replaced the mechanical fuel pump and that didn't work. So I took off fuel line to pump and I noticed no gas coming thru. Guys it was fine day before. So I am stumped I don't have much money left can anyone please tell me what to try next please? I need this truck to get to work. Thank u so much
Rob
roblee is offline   Reply With Quote Quick reply to this message
Old 12-18-2013, 07:27 PM   #2 (permalink)
Azelgin's Avatar
Ok, simple things first. You're sure there is gas in it and the fuel gauge works? When you changed the fuel filter, where was it located? Some people add a filter between the pump and carb, forgetting all about the one under the frame, by the fuel tank. You do mean you disconnected the fuel line between the pump and carb, not the fuel line going to the pump, from the tank? Did you try removing the gas cap, to let air into the tank, in case the charchol canister is plugged?
If, all that checks out, pressurize the line coming from the tank, at the fuel pump and listen for air bubbling in the tank. You'll have to remove the gas cap, as its a closed system. That's all I got, for now.
Old 12-18-2013, 07:46 PM   #3 (permalink)
Why are you troubleshooting a fuel problem for a no crank symptom? A Samurai has a mechanical fuel pump, so no crank, no fuel.
Perhaps now would be a good time to define what "just will not crank" means to you - to me it means that when you turn the key the starter does not crank the engine.
Old 12-18-2013, 08:05 PM   #4 (permalink)
Azelgin's Avatar
Yea, I guess a clarification is in order here. There I go "assuming" that the engine is actually turning over, when the key is turned to start. Thanks, Fordem
Old 12-19-2013, 06:31 AM   #5 (permalink)
Default clarification on my 1988 samurai fuel problems, please help exp. guys out there
Yes it does crank, just no gas going to carb. please folks need your help please.
just will not get gas to carb. I noticed no gas getting to my Carb so I have replaced the fuel filter no luck. So I replaced the mechanical fuel pump and that didn't work. So I took off fuel line to pump and I noticed no gas coming thru. Guys it was fine day before. So I am stumped I don't have much money left can anyone please tell me what to try next please? I need this truck to get to work. Thank u so much
Rob
