Vibration in 4wd after spoa - Suzuki Forums: Suzuki Forum Site
Old 12-16-2013, 05:05 PM   #1 (permalink)
JDM Jimny in CDN is on a distinguished road
Default Vibration in 4wd after spoa
Hey guys and gals,
I performed a spoa on my jimny Sierra a year ago and noticed some vibration in 4hi and low. I have since put in a 1.6 16v with no change to the vibration.
Recently I have put in some 4.9's in my tcase. Now
The vibration is much more apparent. Maybe just cause of higher rpm.
It's fine in 2wd but horrible in 4wd.
I made sure I lined up the marks on my shafts.
I was thinking it may be drive shaft angles. Has anyone bothered to shim out your front diff? Any other ideas?
Thanks in advance for your input
1994 Suzuki Jimny Sierra (JDM samurai) swap to 1.6 16V
1991 Nissan 240sx swapped to SR20DET 275 bhp
2006 Infinity G35 coupe 6MT pretty much stock
2007 Nissan X-Trail 5spd grocery getter
JDM Jimny in CDN is offline   Reply With Quote Quick reply to this message
Old 12-17-2013, 09:50 AM   #2 (permalink)
caseyjones955's Avatar
If you shim the front diff the steering geometry will suffer.
At what speeds does this become a problem?
Are your transfer case mounts stock? What condition are they in?
Old 12-17-2013, 11:20 AM   #3 (permalink)
Hi CJ955 thanks for the reply,
Looks as if we have a very similar engine setup. right down to the thorley! however I may have forgot a Cat.....!
Slight Vibration starts at about 15mph and gets nasty around 30mph.
I also forgot to mention that I have the High steer kit on it as well. So I may avoid any steering issues with diff shims?
Old 12-17-2013, 11:26 AM   #4 (permalink)
Do you really need to be in 4WD at 30 MPH?
I would think that you'd only have to pull yourself out of any problem spot at less than 15 MPH, no?
Old 12-17-2013, 12:57 PM   #5 (permalink)
Yeah you are right Max! but I like it to work properly! 30mph is when it starts to get really bad, it still is apparent at lower speeds.
I do use 4wd on snowy mountain highways! Canadian eh?!
happy 9000th post BTW
Old 12-17-2013, 01:07 PM   #6 (permalink)
9K. Holy crap! Spread over 7 years though.
Can you feel the vibe in the steering wheel? I would think so IF the front shaft is the culprit.
Old 12-17-2013, 01:32 PM   #7 (permalink)
The thing about drive-line changes like yours is not just the drive-line ANGLE needing to be maintained from 1-3 degrees in difference, but you also created a longer drive-shaft requirement. You pulled the spline joint out more, in other words and may have created a less than appropriate "bite" and now a joint wobble.
That and you added a new "U" joint burden, which may have been tolerable before but now requires joint replacement, due to age / wear.
Old 12-17-2013, 04:18 PM   #8 (permalink)
I don't feel to much vibe in the steering wheel, it resonates through the whole body.
I did use a 1' spacer on both front and rear diffs, and it seems there is ample "bite" I measured 3 inches with rear wheels off the ground.
It may be noteworthy that there is less vibe in 2wd with the hubs locked and the shaft spinning. I have not checked my U-joints, how would I do that?
Old 12-17-2013, 04:28 PM   #9 (permalink)
Spacers. Good!
Checking the U joints means pulling the drive shafts and moving the joints through their arc, feeling for a sloppy (worn) fit OR binding.
If the driveline angles are OK and the u-joints check out, you may have to get the driveshafts evaluated for trueness and balance.
Old 12-17-2013, 04:30 PM   #10 (permalink)
Damn.. i did try that out when I had them off last weekend...seemed fine.... Im stuck on this one.... maybe I chucked a weight off my shaft.
