samurai starts but won't run - Suzuki Forums: Suzuki Forum Site
Old 12-08-2013, 05:43 PM   #1 (permalink)
zukin is on a distinguished road
Default samurai starts but won't run
just got a 92 samurai, it will start if I put fuel down the tbi.
will only run until fuel runs out.
installed new fuel pump & filter, tried different ecm from a buddy.
anyone have any ideas or suggestions?
zukin is offline   Reply With Quote Quick reply to this message
Old 12-08-2013, 07:28 PM   #2 (permalink)
gregman is on a distinguished road
Here's a thought or two:
1) Check fuel pump relay if you have one
2) Was the ecm from the same type of transmission? Manual ECM different from Automatic ECM...
Love my putt putt !!!!
1991 8V 1.6L 2Dr 4X4 Sidekick.....original Canadian owner !!!!! 340,000+ km and going!! 22 yrs old...
gregman is offline   Reply With Quote Quick reply to this message
Old 12-08-2013, 07:35 PM   #3 (permalink)
maybe I should have mention this is a samurai.
new fuel pump works fine have gas right up to the tbi.
ecm came from 91 samurai so it is the same as my 92
Old 12-08-2013, 08:12 PM   #4 (permalink)
oops....you're right...Samurai different from Sidekick...sorry....just trying to help.
Old 12-09-2013, 06:42 AM   #5 (permalink)
Guest
Have you tried pulling codes while cranking? the ECU looks for a feedback signal from the ignition and if it doesn't see it it will cut fueling.
Old 12-10-2013, 06:24 AM   #6 (permalink)
I have check engines with fuse in service slot in fuse panel with ignition on, it give engine code 12 which means everything is normal.
didn't know you could check codes when cranking?
Old 12-10-2013, 06:45 AM   #7 (permalink)
Guest
Cam sensor codes only show while cranking. Have you got a noid light? you should check the the injector is receiving a signal from the ECU.
Old 12-15-2013, 08:31 AM   #8 (permalink)
what tells the ecm to pulse the injector?
Old 12-15-2013, 09:47 AM   #9 (permalink)
Guest
The camshaft sensor but you have spark so that should be OK. Did you check the codes while cranking? if that still shows OK then its probably a faulty ECU.
