Not idling or just dies out - Suzuki Forums: Suzuki Forum Site
Old 10-19-2013, 06:58 PM   #1 (permalink)
smbearkat90 is on a distinguished road
Default Not idling or just dies out
I am trying to figure out what's wrong with 87 Samurai. When starting cold,shift 1st gear or going reverse then when I stopped or just sitting to idle, engine dies out. It does this several times on every stops until engine gets warmed up for at least 15-20 mins running then it don't die out. Mechanical fuel pump is pumping, depress with finger on EGR valve seemed fine, fresh gas tank is full. What do you suggest I need to look for to solve this issue?
smbearkat90 is offline   Reply With Quote Quick reply to this message
Old 10-26-2013, 07:54 PM   #2 (permalink)
glenn88sam is on a distinguished road
Default idling issue
i am having the same trouble with mine and blamed it on age and miles on my lil 1.3. till today its started same as usual cold natured but started right up i feathered gas to help get choke set and smoothe it out. it died and will not start back at all. changed out coil today still no luck. i will be figuring it out hopefully tomorrow if you have solved this issue or have any ideas please let me know. As soon as i figure it out i will post what problem is/was so you have something to check.
good luck
glenn
glenn88sam is offline   Reply With Quote Quick reply to this message
Old 10-27-2013, 09:33 AM   #3 (permalink)
Guest
I would suspect a sticky autochoke mechanism.
Old 08-13-2014, 02:34 PM   #4 (permalink)
digitalw is on a distinguished road
Have you figured it out what was the problem.? I have the very same problem with my 2009 jimney.
digitalw is offline   Reply With Quote Quick reply to this message
