Ignition/coil problem - Suzuki Forums: Suzuki Forum Site
Old 10-08-2013, 08:39 PM   #1 (permalink)
Jelloats is on a distinguished road
Default Ignition/coil problem
I have an 88 Samurai. I have no spark out of the distributor. The coil is sending spark to the distributor. The rotor and distributor cap seem fine. When I rotate the #1 cylinder to Top Dead Center, the rotor is at the correct position in the distributor.
Could the electronic ignition be telling the coil to fire at the wrong time, even if the timing at the distributor is correct?
Jelloats is offline   Reply With Quote Quick reply to this message
Old 10-08-2013, 09:36 PM   #2 (permalink)
The electronic ignition is contained entirely in the distributor - so no - it's firing at the correct time, based on the "cam" in the distributor - chances are you have either a defective cap or rotor.
Old 10-08-2013, 10:13 PM   #3 (permalink)
morbo's Avatar
morbo is on a distinguished road
I had Similar problem after dumping a g16a motor in. I ran a extra thick earth lead off the back of the dizzy (bottom bolt). All 2 mechanics and my self could figure out was it was stealing too much power on turn over to spark well.
morbo is offline   Reply With Quote Quick reply to this message
Old 10-08-2013, 10:26 PM   #4 (permalink)
Default Thanks
Ok. I'll try a new cap and rotor, and check the ground.
Thank you both very much.
Old 10-09-2013, 07:28 AM   #5 (permalink)
morbo
I can't help but wonder if you were missing the block to battery negative lead - there is usually a heavy cable between the battery negative and one of the bellhousing bolts - it provides a return path for the starter current, and if it's missing (or not making proper contact) you'll get exactly the problem you describe.
Old 10-09-2013, 02:52 PM   #6 (permalink)
morbo's Avatar
Yah she was hooked up all right , Even started once, Got a feeling the 1.6 adapter plate was stopping good current flow. fortunately i have a old zook for parts in the paddock , Did the dizzy swap and all before we ran a second earth.
g16a powered 89 zook, because i can fix it
2005 x -cop BMW 1150 rt ,Because i don`t have too
