Some Assembly Required... - Suzuki Forums: Suzuki Forum Site
Old 07-21-2013, 06:01 PM   #1 (permalink)
hotrodsami's Avatar
Default Some Assembly Required...
I have finally bitten the bullet and decided to put an after market ignition system on my samurai. I was not looking for something to give me a more powerful spark but something that would let me re-curve the timing to better suite running on propane. After some research I decided to go with the programmable high energy ignition system from Jaycar Electronics in Australia as it will require little modification to my rig and I won't need to find or manufacture as many parts. The down side is that the term some assembly required has taken on a whole new meaning.
I am not going to go through the details of assembling the kit the instructions that come with it have all the details you will ever need but I will try to document how I get this kit to work on the samurai so if some one is foolish enough to follow in my footsteps there will be some info on how it might be done.
[FONT="Comic Sans MS"][SIZE="3"]Failure is [U][I][SIZE="4"]always[/SIZE][/I][/U] an option[/SIZE][/FONT]
hotrodsami is offline   Reply With Quote Quick reply to this message
Old 07-22-2013, 09:17 PM   #2 (permalink)
steelbreeze is on a distinguished road
Wouldn't an adjustable timing gear accomplish what you needed or not the same curve you want??
steelbreeze is offline   Reply With Quote Quick reply to this message
Old 07-23-2013, 05:09 PM   #3 (permalink)
hotrodsami's Avatar
An adjustable timing gear will get the same result as setting your distributor timing but it also changes the timing of your valves. Propane requires a faster curve, more advance in the same RPM range, than gasoline.
Example: As far as I can determine from the initial 10deg. it rises to 20deg. at 2000 rpm at witch point the centrifugal advance is done only the vac advance can get it higher. On propane I can start with the same 10deg. but might need to go to 25deg. at 2000 rpm.
That being said if I could find an adjustable timing gear for a suzuki samurai I would already have one but I haven't seen one for sell in years.
Old 07-24-2013, 12:59 PM   #4 (permalink)
VaderSS's Avatar
Garage
Suzuki Samurai engine pulleys
Wayne Bengston
Old 07-24-2013, 04:34 PM   #5 (permalink)
Those are the ones he was referring to when he mentioned they haven't been made for a few years. Note, at the bottom says temporarily out of production. When I get home on my laptop I will send a link to a site I am ordering one for my 1.6 and I believe they also have for the 1.3. Just can't find from my phone. I have it saved on my laptop. Hang in there bebe
Old 07-24-2013, 06:05 PM   #6 (permalink)
HERE'S THE LINK TO THE ONE FOR THE 16 VALVE. I BELIEVE THEY HAVE FOR 8 VALVE ALSO.
Aluminum Adjustable Cam Gear SOHC 16V [SUZ-ADA-6134-16V] - $199.00 : Suzuki Racing Development
hERE'S THE ONE FOR THE 8 VALVE
Aluminum Adjustable Cam Gear SOHC 8V [SUZ-ADA-6134-8V] - $175.00 : Suzuki Racing Development
