2 new issues. Temp rising and starter - Suzuki Forums: Suzuki Forum Site
Old 07-04-2013, 10:02 AM   #1 (permalink)
Cpolson15 is on a distinguished road
Default 2 new issues. Temp rising and starter
So my new issues with my 94 Sammy. First when driving if I switch on the headlights the temp rises a significant amount. If they are turned off it drops back to normal. When the ac is on the temp does not rise as much. Didn't think that the lights would cause that much draw as to out that much load on the engine. Do I need a new alternator. Also now I am having an issue starting. When I turn the key the starter cranks continuously and it won't start until I let go of the key. Normally it would crank start after a few revolutions and then I would let go of key. Now it will just keep cranking until I let go then start. I also have the clicky starter fix installed. Sometimes it also seems like the starter gets stuck for a second and then frees itself. So don't know if I need a new starter or if its the clicky fix going bad. I just put it on a few months ago.
Thanks for the help in advance.
95 Sidekick JLX
94 Samurai JL
Cpolson15 is offline   Reply With Quote Quick reply to this message
Old 07-04-2013, 10:27 AM   #2 (permalink)
First - I'm pretty certain that the engine temperature is not rising when you switch the lights on - I suspect you have a gauge problem, and the only way to verify this is to get the actual temperature reading - either from a mechanical gauge, a test meter with a temperature probe or an infrared thermometer.
Is the temperature change instantaneous - rising as soon as you switch on the lights, falling as soon as you switch them off - or is it gradual. It takes time for an engine to warm up or cool down, so if you're seeing a rapid change, chances are you're watching the gauge reacting to an electrical change rather than the engine responding to the load.
My suspicion is one or more bad grounds, I'd start with the one between the battery negative and the bell housing, and then the one between the battery negative and the frame/body.
Old 07-04-2013, 10:34 AM   #3 (permalink)
The temp is a gradual increase up when lights on and a gradual decrease when lights off. And when it starts to go up it will finally hit the thermostat temp point and it will open and then temp will go down a bit. But I don't think it's electrical although I have not checked out the wiring for the lights. It has done this since I bought it but now that I flushed coolant and replaced thermostat it seems to be rising a little higher. At times it gets about 1/4 inch from the red.
95 Sidekick JLX
94 Samurai JL
Old 07-04-2013, 10:37 AM   #4 (permalink)
Just curious as to where other people's operating temps are. With lights off and no ac mine usually rides at the halfway point. Lights on goes up sometimes to 1/4" from red depending on outside temp. With ac on goes up just a little past halfway. Now with ac on and idling in a parking lot the temp almost hits red. And I have the electric fan working. So just wanting to know if others are in the same spot.
Thinking I might need a new fan clutch.
95 Sidekick JLX
94 Samurai JL
Old 07-04-2013, 10:51 AM   #5 (permalink)
You've got something very strange going on there - what I would expect, from a cold start, the engine will warm until the thermostat opens at which point the temperature should stabilize - I've never seen a case where it rises until the thermostat opens and then falls, and I've never seen one where switching the lights on would cause a temp increase.
There's also the suggestion (in the first post) that the lights are causing a greater loading than the a/c, which is highly improbable - although I guess it is possible that the additional air circulation caused by the condenser fan might provide enough cooling to skew the observation.
I'll leave it to the Samurai drivers to tell you what they see on their gauges, but I suspect you'll find quite a variance - the temp gauges are not precision measuring instruments - which takes back to my original suggestion, using an external measuring device.
Old 07-04-2013, 02:50 PM   #6 (permalink)
hotrodsami's Avatar
My temp gauge will vary widely depending on out side temp. In summer going down the highway it will stay at about the halfway point to just over halfway. In town or on the back roads it will drop to about a third of the way up. In winter it never gets above 1\3 on the highway and in town or the back roads it will stay at about 1\4, I have to block off part of the rad the get it to run right in the winter.
I don't have a\c and the head lights don't make any difference on the temp.
'88 samurai running on propane.
[FONT="Comic Sans MS"][SIZE="3"]Failure is [U][I][SIZE="4"]always[/SIZE][/I][/U] an option[/SIZE][/FONT]
hotrodsami is offline   Reply With Quote Quick reply to this message
Old 07-04-2013, 02:56 PM   #7 (permalink)
Mine will normally run at halfway maybe a little below during summer or winter on the highway. On back roads it does drop a little in winter but summer still runs at mid point. Just don't understand about the lights and now my starting issue. I'm starting to wonder if the ECM might be to blame. Has never been fixed or replaced.
95 Sidekick JLX
94 Samurai JL
Old 07-04-2013, 02:58 PM   #8 (permalink)
Guest
I would suspect a ground problem or a bad voltage regulator in the cluster.
Old 07-04-2013, 03:23 PM   #9 (permalink)
Ok so here's an update. Idling in driveway when I turn the lights on the idle drops like under load. Unplug both headlights and no change. Seems to be only in switch. Also only drops idle when headlights are on. Running lights does not affect idle. So one would think if I unplug headlights idle would go back to normal but does not. So I am suspecting switch. Also still dealing with starting issue. Used to crank once and fire. Now have to hold key and like I said before will not actually fire until I let go of key. After its warm one revolution and it fires.
Also checked all grounds and they are good. PO had main ground from battery disconnected but I fixed that when I installed clicky fix. Also when I unplug coolant temp the electric ac fan comes on so it seems to be operating properly.
95 Sidekick JLX
94 Samurai JL
Old 07-04-2013, 04:05 PM   #10 (permalink)
I was going to suggest you switch the lights on/off and see what effect it has on the idle speed, but I decided against it - the drop in idle speed may have no bearing on the load on the engine.
I'm not certain what idle speed control mechanism your Sami has (or what condition it is in), but Suzuki uses an "idle up" system which is designed to bump the idle rpm up when an electrical load is switched on (or the a/c or power steering is in use) to compensate for the increased load - on carbed engines it's done via a vacuum switching valve and an actuator that moves the throttle stop, EFI engines use whatever idle speed control mechanism they are fitted with to achieve the same thing (usually some sort of throttle plate bypass) - the problem here is that if the "idle up" is not working or out of adjustment, it can cause the idle speed to not increase when it should or even decrease - without the loading on the engine changing in the slightest.
I really don't see a defective light switch being able to load the engine to the point where it's noticeable in the idle speed - without the switch burning up - but, on the other hand, just turning the switch on activates the idle up compensation circuit, and that may be what's affecting the idle speed.
