starter motor or battery? - Suzuki Forums: Suzuki Forum Site
Old 06-01-2013, 08:40 PM   #1 (permalink)
zuk4life88 is on a distinguished road
Default starter motor or battery?
so i have replace a complete motor and trans 1300cc into my 88 samurai, the problem is when i turn the key.... it turns over so slowly rarely actually is able to fire the motor up, i thought it was the battery, but i grabbed the battery from my other samurai which always turns the motor and it also barely cranks the motor... i have tried two other batterries but with the same result it may start the crank the motor over... slowly then fire. but when i shut it off and try to start it aghian it wont crank or barely crank. also the alternator is good cuz when i do get it running and disconnect the battery it seems to keep runnig fine and i do believe the alternator is pumpin out 14volts.... so any help would be great. thanks:
zuk4life88 is offline   Reply With Quote Quick reply to this message
Old 06-01-2013, 09:39 PM   #2 (permalink)
Gallery: 3
Garage
Sounds like a bad starter. Have it load tested.
Boxcar is offline   Reply With Quote Quick reply to this message
Old 06-02-2013, 08:11 AM   #3 (permalink)
Check the engine and battery GROUND cable / connections for tightness (or missing?).
Old 06-02-2013, 07:02 PM   #4 (permalink)
harley4jcs is on a distinguished road
DITO, Just have it tested while you are buying the new one.
harley4jcs is offline   Reply With Quote Quick reply to this message
Old 06-03-2013, 01:25 PM   #5 (permalink)
94zuke is on a distinguished road
it could possibly be off time check that to, my jeep done the same thing and just a turn of distributer fixed the problem, have not had any problems out of sammy yet
94zuke is offline   Reply With Quote Quick reply to this message
Old 06-03-2013, 02:31 PM   #6 (permalink)
Joe Z is on a distinguished road
How true..... I forgot about that possibility. If it's too far advanced it will give that type of symptom ..... try marking where the distributor is now and move it back more toward retard and see if it spins faster then put a timing light to it if it does.
Joe
Joe Z is offline   Reply With Quote Quick reply to this message
