Problem with clutch - Suzuki Forums: Suzuki Forum Site
Old 01-01-2013, 07:41 AM   #1 (permalink)
Superbock's Avatar
Superbock is on a distinguished road
Default Problem with clutch
I have a samurai 1.9td. I have just taken the gear box out to replace worn first gear synchro. After much struggling the gear box slipped back in but now I can't seem to get it into gear. I have tightened the cable until there is almost no free play at the release arm. The clutch feels spongy when pressed. Could I have damaged the clutch or spring release putting the gear box back in? Or do I just need to tighten the cable more? Please can any one advise before I take the gear box out again.
Superbock is offline   Reply With Quote Quick reply to this message
Old 01-01-2013, 08:10 AM   #2 (permalink)
Gauge your "play" at the pedal. Hopefully you just need to adjust the cable tighter, as opposed to having a release bearing / clutch actuation shaft assembly problem, a worn out cable or cable bracket (attachment) issue.
Old 01-01-2013, 02:28 PM   #3 (permalink)
Superbock's Avatar
Thanks Max for advice, I can see the logic . Have tightened clutch at pedal until the bolt almost fell out but still can't get into gear. I will try measuring length of clutch cable to see if it has stretched. When moving her with the engine off I hear a grating noise from the bell housing, never noticed this before?
Old 01-01-2013, 04:20 PM   #4 (permalink)
THAT doesn't sound good. Assembly error?
Old 01-04-2013, 09:41 PM   #5 (permalink)
Jake terry is on a distinguished road
The "play" is that when you push down on the pedal an till it begins to get get tough ?
Jake terry is offline   Reply With Quote Quick reply to this message
