rear wheel bearing replacement - Suzuki Forums: Suzuki Forum Site
Old 12-15-2012, 11:53 AM   #1 (permalink)
cherrybombinJX's Avatar
cherrybombinJX is on a distinguished road
Question rear wheel bearing replacement
hi . i was wondering if anyone could tell me whats involved in pulling a rear wheel bearing on my 1986 samurai JX . i've had it apart partially in the past to check that it was the bearing going out . and i found that the axle shaft move's about 1/4" side to side . so it is the bearing . but anyway i was wondering if it is just as simple as it looks to be ? . from what i understand the following is what has to be done . pull the wheel and tire off then pull the brake drum . unhitch the parking brake cable and brake line . the zip out the four bolts holding the backing plate to the axle houseing and pull the axle and bearing out . if im missing something here it would great if someone would let me know . thanks
cherrybombinJX is offline   Reply With Quote Quick reply to this message
Old 12-15-2012, 09:37 PM   #2 (permalink)
Rear Axle breakdown
The big problem is removing the the bearing retainer as you need to cut or grind it down. Most use a grinder to grind down one side of the retainer without damaging the axle. Once you are almost through, you should be able to knock it loose.
When installing the new retainer, cool the axle down in the fridge and heat the retainer in the oven. Should slip on easier that way.
Old 12-16-2012, 12:19 PM   #3 (permalink)
thanks very much haptown . by the way does the actual bearing press on ? . or does it just slide on and then the retainer is pressed on ? . thanks very much
Old 12-16-2012, 01:55 PM   #4 (permalink)
The bearing is pressed on and will take some force to remove.
Samurai FSM rear axle bearing section pdf download
Since you are removing the axle bearings, now would be a good time to do the SJ410 retainer plate mod in case you ever need to remove the axle again.
SJ410 retainer plate mod how-to
Old 02-19-2013, 11:56 PM   #5 (permalink)
hi guys , long time no see , i've been really busy lately , and just now getting around to ordering the parts to do the sj410 retainer plate mod and new bearings , ect , just had one more question , from what i can see from the pics in the sj410 retainer plate how to (thanks haptown for the info) is that it is a non sealed bearing that gets lubricated via the gear oil in the diff , am i right on that fact or do i need to grease the bearing before installing it ? , thanks again for all the info
