4WD light always on - Suzuki Forums: Suzuki Forum Site
Old 10-27-2012, 04:52 PM   #1 (permalink)
ChiefZuki is on a distinguished road
Default 4WD light always on
Quick question regarding the 4wd light. The owner said it has been on for about the 7 years they owned it. I would like to diagnose this problem so I can be sure when I'm alone that I'm out of 4x4 without driving down the road. I have a Haynes manual but they lack details on where the wire routing starts. Just wondering if anyone has had this problem before and the best way to go about fixing it without tracing back wires. Thanks
ChiefZuki is offline   Reply With Quote Quick reply to this message
Old 10-27-2012, 06:39 PM   #2 (permalink)
First - letting us know what vehicle you're asking about improves your chances of getting a helpful answer - later model Jimny's are very different to the earlier vehicles.
Second - I doubt there's a way to troubleshoot this without tracing wires.
On the Sierra/Samurai the 4WD light is controlled by a switch on the transfer case - the switch could be defective or the wire shorted to ground - start by checking the switch, and if that's not it - get tracing ...
Oh - a good diagram might help - if it's a Sami, check Ack's FAQ.
Old 10-27-2012, 08:25 PM   #3 (permalink)
Hello, thanks for the feedback I apologize I wasnt more specific.
It is a 1986 Samurai conv. If tracing the wires will solve my problem then so be it, I guess what I meant by saying I didnt want to trace wires is that I wanted a general ideas of where the wires might be or what to look for once I am tracing said wires. In the wiring diagram in the Haynes manual it gives the colors of the wires so I can look out for those. I will trace back power and ground from the tcase sensor and see what I come up with.. thanks
Old 10-27-2012, 11:23 PM   #4 (permalink)
Oh and by the way, I did find a stray red wire near the fuse box underneath the drivers side dash. I don't know if this is of any relevance but thought I would point it out
Old 10-28-2012, 01:20 AM   #5 (permalink)
Igolf is on a distinguished road
As Fordem says,"the switch is located on the top of the transfer case". Go under the Sami and look to the top of the transfer case. The switch can be unplugged. I believe the wires to the switch are blk and blk/Bl tracer. Guess is you have a bad switch or a wire is grounding out.
Igolf is offline   Reply With Quote Quick reply to this message
Old 10-28-2012, 10:30 PM   #6 (permalink)
What they ^^^said.
A buddy bought a Sami that had been cobbled together
from several years of them. Mixed square holes with
round ones in the dash,(round 86to88,square late 88 on)
We found that the dash lights were not all compatible
through the years. His 4X4 dash light was not really
related to the transfer case. Turned out that the lamp
behind the 4X4 symbol was really the check engine
lamp and it was on all the time because of the Suzuki
re set switch on the steering tube.
Once reset the lamp went out but was not affected
by the transfer case switch.
Someone had switched the dash gauge panel with
another that fit but the circuits were not compatible.
Just sayin'
Old 10-28-2012, 11:53 PM   #7 (permalink)
Thanks for the advice, I tried to trace the wires today but they went up into a spiral of other wires and I didn't have much time to keep looking at it. Is there any known spots for grounds? Hate to sound like a pain, I know that might be a difficult request.. I posted pics below of the only loose wires I could find. A red wire by the fuse box, and two different wiring harnesses in the engine bay have nothing to plug to. My biggest question is to what these might go to
Old 10-28-2012, 11:54 PM   #8 (permalink)
Oh yeah the only other thing to my knowledge that doesn't work electronically is the dome interior light
Old 10-29-2012, 06:38 AM   #9 (permalink)
The light is on all the time, so you're not really looking for a loose wire - more for a short to frame, although, it's entirely possible to have both - if a previous owner disconnected the wires during his troubleshooting.
According to the diagrams at Ack's FAQ, you're looking for a 2 wire connector - black (ground) and blue with a black tracer - I seem to be seeing blue on that connector, but not blue with black.
It really might be easiest to pickup the wiring underneath near the transfer case, or near the transmission tunnel
Old 10-30-2012, 12:02 AM   #10 (permalink)
Thanks for the advice, I can try to trace them again. Those pictures I took of the loose wiring harnesses were in my engine bay near the drivers side headlight. They're unrelated, but I posted the pics to see what could come of it.. When I traced the wires from the transfercase, they went up into a bunch of other wires taped up, going into the cabin I presume?
