Stock Engine Can't Be Rebuilt? - Suzuki Forums: Suzuki Forum Site
Old 08-10-2012, 02:48 PM   #1 (permalink)
DrewtheMew is on a distinguished road
Question Stock Engine Can't Be Rebuilt?
Hey guys, been working on my 87 zuk for the past month trying to get her roadworthy again. Back in May, I had dropped in a used g13A motor bought from a local engine rebuilding firm. It worked fine for a month, then started burning oil; almost two quarts ever two weeks. After trying all the hotfixes the firm recommended, which almost never work anyway, I pulled the engine out and had them rebuild it under warranty. So I dropped it in last week, set the timing and it wouldnt fire up. Camshaft was out of timing even though they said it was.
Now with that worked out, the engine started up, ran fine for about 30 seconds before abruptly stopping, ie, it locked up. Took it to the local mechanic i know, he said the oil pump is bad in it. One of the other guys working there also mentioned you cant rebuild these engines, if the crank is bad, you need a new block.
Do you really need a completely new engine if the main bearings stick? I've already talked to the firm and they said they'd completely rebuild the engine again, new crank and pump, under warranty again. Should I have it rebuilt again or am I wasting my time? Any info would be more than appreciated!
DrewtheMew is offline   Reply With Quote Quick reply to this message
Old 08-10-2012, 03:47 PM   #2 (permalink)
Either your mechanic is clueless, or, you have misunderstood what you've been told.
Most engines can be rebuilt, and I know these certainly can - because I have done it, and put 30,000+ miles on it "post rebuild" - also - the crank that's in my engine did not come in it, so cranks can be swapped if necessary.
It is possible, and indeed probable that if YOUR engine siezed from being run with with low oil pressure, that you COULD have spun one or more bearings, which COULD damage both the block and the crank, and that YOUR particular engine cannot be rebuilt, without extensive (and expensive) machine shop work.
If the engine/vehicle were rare enough (and worth enough) you could have the crank reground and the block and main bearing caps faced & line bored, but these engine are plentiful, so I suspect you could find a complete replacement for less than the cost of the work involved.
What can be done and what needs to be done will depend on what was damaged when the engine seized, and that can only be determined after tearing it down - you cannot even determine that a defective oil pump was the cause of the problem before the tear down - you can only guess.
Old 08-12-2012, 10:54 PM   #3 (permalink)
rey0176 is on a distinguished road
yea this mechanic is clueless....
rey0176 is offline   Reply With Quote Quick reply to this message
Old 08-12-2012, 11:08 PM   #4 (permalink)
Yeah I dont believe hes right on this one. Several forums on rebuilding these things. Anyway, we're taking the engine back to the guys we got it from tomorrow. If its shot, theyll get us a new motor and rebuild it for free. If it isnt shot, theyll replace anything that needs replacing for free. So we'll find out later in the week, thanks for the reply!
Old 08-13-2012, 01:55 PM   #5 (permalink)
87 TinTop's Avatar
87 TinTop is on a distinguished road
Can you just get your money back? I wouldn't trust them to rebuild anything with all the problems you've had.
87 TinTop is offline   Reply With Quote Quick reply to this message
Old 08-14-2012, 12:19 PM   #6 (permalink)
Might be the case Tin, they called back saying its our fault the motor failed on startup. Claimed the oil pump is fine, even though the oil was full of metal flake and having virtually no oil on top of the engine. They say theres a gasket between the oil pickup tube and the block that wasnt replaced, and wasnt included with the set that they gave us, and all the oil from the pump leaked out before it went up to the top of the engine. And to add insult to injury, they said this gasket isnt made anymore, you have to make them yourself, and that it should be replaced along with the oil pump gasket which we had to buy for them because their shop was out. How can we be at fault here if such a gasket did exist on the vehicle? I dont remember seeing one on there when i took the pickup tube the first time...
Old 08-14-2012, 01:18 PM   #7 (permalink)
The oil pick up tube has an O ring rather than a conventional gasket, and if I remember correctly, the O ring is not supplied as a part of the rebuild gasket set, you have to purchase it separately - it IS available, all of your normal rebuild parts - gaskets, seals, piston & ring sets, bearings - can be sourced from Suzuki (although that's probably a pretty expensive way to go) - the only thing used in my rebuild that was not OEM Suzuki were the high compression pistons, but pistons were available.
If that O ring was left out, the oil wouldn't leak out before it went up to the top of the engine or be full of metal flake - the oil pump would simply not prime because it was sucking air, the oil would remain in the pan, unused, and no have metal flakes in it.
Now - I'm not defending the rebuild firm - but someone has to take responsibility for certain "critical tasks" - when the engine was installed, whoever did the installation would have had at the very least to fit a filter and fill the engine with oil, that person should have verified, prior to starting the engine, that there was oil pressure & circulation - was that done?
A fairly common mistake on these engines is to flip the head gasket end for end - it will appear to fit, and all of the bores, etc. will line up - except for one oil way at the front of the head, bolt up and the engine will have oil pressure, will start & run beautifully for about 20~30 minutes, after which the cam will seize because of a lack of lubrication - visually verifying that oil is reaching the head by cranking the engine over with the plugs out is the only way to check for this.
Old 08-14-2012, 08:21 PM   #8 (permalink)
Well when the firm tells you, "Its ready, you just need to reassemble it and drop it in." with no mention of the non-existing gasket, how can we be to blame? I did make sure to oil everything up prior to startup. How do you check oil pressure before the engine had ever been started? The engine ran for 30 seconds when it locked up, not minutes. They said all the main bearings are shot and the cam is ok, but there was little to no oil on the top of the engine. How would that gasket not being the leave the cam intact but destroy the crank?
Old 08-14-2012, 08:50 PM   #9 (permalink)
"It's ready, you just need to reassemble it and drop it in" can mean a thousand different things - just as an example - when I rebuilt my engine, I dropped the bare block off at the machine shop along with the pistons, so that it could be bored, and when I picked it up, I just needed to reassemble it and drop it in.
Yeah - I know - not the same thing, I rebuilt my engine, you bought a rebuilt one - but - you get an idea of just how much can be misunderstood.
As another example - if you picked it up, minus the oil pan and the pickup, then you're responsible for making sure that the pickup has the O ring - we don't know degree of assembly you were required to do.
How do you check the oil pressure before starting - depends on the engine, but for these, fit a gauge or at the very least the oil pressure switch, hook it up, and crank the engine over with the plugs out - it'll take a couple of minutes to prime the pump, fill the filter and the galleries - so crank for 30 seconds, wait 60 to let the starter cool, crank 30, wait 60 and so on, until you get pressure.
Old 08-14-2012, 10:39 PM   #10 (permalink)
Would turning it over for 3 minutes prime it? Because they gave us it back with the cam out of sync. We sent almost 2 hours trying to get it to run, ie cranking several times over and over again without it starting up, but couldnt dew to the cam. That alone should have primed it if the oil pump were in working order correct?
