Filling Transmission Fluid - Suzuki Forums: Suzuki Forum Site
Old 08-06-2012, 12:06 PM   #1 (permalink)
diego2012 is on a distinguished road
Default Filling Transmission Fluid
Read somewhere you can just fill the transmission fluid through the shifter knob? Is this true?
And what are you guys running? 75w90?
Thanks!
diego2012 is offline   Reply With Quote Quick reply to this message
Old 08-06-2012, 12:50 PM   #2 (permalink)
razor02097's Avatar
Automatic or a manual?
If it's a manual... I use redline mt-90. It's a GL4 75W90 synthetic. You want to fill the transmission at the fill plug. If the level is too high you can damage the transmission.
[URL="https://www.suzuki-forums.com/suzuki-sidekick-escudo-vitara-geo-tracker/53477-project-tetanus-warning-picture-heavy-thread.html#post338794"][IMG]http://i108.photobucket.com/albums/n21/mino9991999/b6vkvght_zpsef160e4e.jpg[/IMG][/URL]
razor02097 is offline   Reply With Quote Quick reply to this message
Old 08-06-2012, 01:26 PM   #3 (permalink)
Got it. Just trying to avoid pumping it in but looks like I need to. Yeah... manual.
Old 08-06-2012, 01:31 PM   #4 (permalink)
razor02097's Avatar
No need for a pump... make yourself a diff bong.... get a large capacity funnel and a long piece of vinyl tubing. hire a helper to hold the funnel and pour in the fluid while you hold the other end of the tube in the filler hole. Go one quart at a time and have a CLEAN drain pan under the trans to catch any fluid that drips out.
The diff bong is traditionally used on differentials but can be used on anything you need to put fluid in under the vehicle. Traditionally constructed on the trail when one needs to break into their differential for repairs.
Another variation I saw on Gearz was using an enema bottle you get from a drug store. Looks like the rubber thing mom used to put hot water in and give someone with a stomach ache but has a long piece of tube sticking out of it. Fill with tranny fluid and away you go.
Old 08-06-2012, 04:08 PM   #5 (permalink)
Haha... Okay. I'll try the bong vs the enema.
Old 08-07-2012, 11:22 AM   #6 (permalink)
I usually just pulled the shifter and the top filler plug.
Using a long funnel, I just added through the shifter opening until a helper reported the oil coming out of the fill plug hole. Fast and easy.
Bill
in old El Paso...
Old 08-17-2012, 12:51 PM   #7 (permalink)
precious566 is on a distinguished road
I assume you could use this same method with the transfer case as well ?
precious566 is offline   Reply With Quote Quick reply to this message
Old 08-17-2012, 10:39 PM   #8 (permalink)
You're catchin on!
Why make it harder (or more expensive) than it has to be...
Bill
in old El Paso...
