86 sammy tranny flush/cleaning help please ! - Suzuki Forums: Suzuki Forum Site
Old 07-31-2012, 03:34 PM   #1 (permalink)
basnbud is on a distinguished road
Default 86 sammy tranny flush/cleaning help please !
So the PO told me the rear seal was leaking and needed replaced. So the tranny has to come out right ? When I drained it before dropping it, there was the nastyest black, bubbly, thick goop that came pouring out of the drain hole. Upon futher inspection, it looked as if a lil water may have got into the tranny. (I think PO liked mudding) so we called a tranny shop, and asked if we could bring it in to get flushed out. The owner said it would not be a good idea to flush it out due to the age, and it prob would mess it up if we cleaned it out real good.
So, my question is, what can I put inside this thing to get it at least half way clean and back on the sammy with out worring about it shittin the bed in a thousand miles ? The manual says to use 75 weight gear oil. I was wondering if I could put some lighter weight motor oil in it and run it a hunderd miles or so then drain it out and put the right oil in it.
P.S. the rear seal was dry as a bone. it was the oilpan that was leaking. oh and the front seal also, but that will get changed next payday/ open weekend (if I don't decide to go fishing instead!)
thanks guys for any help !
Basnbud
basnbud is offline   Reply With Quote Quick reply to this message
Old 07-31-2012, 05:38 PM   #2 (permalink)
anybody know ?
Old 07-31-2012, 06:04 PM   #3 (permalink)
Are we talking about a manual transmission or an automatic transmission - mmm - 75 weight oil, I'd guess a manual transmission.
I'd fill it to the full line with diesel fuel and then, with the car on stands, let it idle in gear for a bit (so that every thing revolves and passes through the diesel, and then drain and refill with some cheap 75W oil, and repeat the idle and then drain & refill with a good quality 75W90 oil.
I'm no transmission expert - but that's what I would do - if it were my transmission.
I've pulled apart a few transmissions and put them back together, and back when I worked with NCR corp, I would take a transmission into to the shop and put it in the booth and pressure wash the entire thing with varasol - get rid of all the mud, grease & grime and it would come out sparkling clean - I would then change any bearings or seals that needed changing - or just drop it back in and fill it with oil and drive.
Never had one fail afterwards.
I'd say if you have a transmission full of muck fail a few hundred miles after you clean it out, the failure was "pending" and would have happened even if you left it alone - you'd probably extend the life by cleaning it and replacing the oil.
One last thing - nothing I've said above should be considered as applicable if the transmission is an automatic - manual transmissions are essentially a bunch of gears & bearings, along with shifter forks and stuff - automatics have the gears & bearings and also valve bodies with valves and passages that can be clogged if you free up muck and then it gets in the wrong place.
Old 08-01-2012, 12:00 AM   #4 (permalink)
thanks fordem, yeah it a manual, sorry for not stating. I'll throw it back in and try your method. i'll let ya know how it goes. first i have to wait on the shifter bushing to come in and get that back in.
basnbud
Old 08-12-2012, 08:01 PM   #5 (permalink)
precious566 is on a distinguished road
Did Fordem's suggestion fix the problem?
precious566 is offline   Reply With Quote Quick reply to this message
Old 08-13-2012, 12:33 AM   #6 (permalink)
yep. cleaned it out good. got some gear oil in now, gonna run it a lil bit then put some redline in it. thanks fordem
basnbud
Old 08-13-2012, 01:47 PM   #7 (permalink)
You're welcome - don't forget to give us an update after you put a few thousand miles on it.
