what size lift for 35s - Suzuki Forums: Suzuki Forum Site
Old 07-25-2012, 08:37 PM   #1 (permalink)
midwayhunter is on a distinguished road
Default what size lift for 35s
Im new to the suzuki world and need some help. I just got my first 88 Samurai and its all stock. I want to put a lift and bigger tires. Ive heard about spring over kits but dont know how high to go. What would be the right kind of lift for an economy budget and maybe put 35" tires? Could these tires and lift be done by a back yard mechanic? How tall of a lift would i need for these tires?
Thanks for the help
midwayhunter is offline   Reply With Quote Quick reply to this message
Old 07-26-2012, 01:34 AM   #2 (permalink)
This is on 33's... and because of the aggressive nature and much heavier tire weight, this lift is no where near an 'economy budget'. If you want to go cheap, stay with 30's and a 2" lift. Otherwise it starts to get expensive fast. My rear axle alone is worth more than most folks spend just buying a stock Samurai.
Bill
in old El Paso...
Old 07-26-2012, 01:39 AM   #3 (permalink)
I know that wasn't very clear. Sorry.
The bigger (and more aggressive) the tire, the more it will cost to keep components from exploding on the trail when trying to turn them. Stock Suzuki axles aren't strong enough to handle more than a 33" tire when actually used on a challenging trail.
Oh, and Welcome!
Bill
in old El Paso...
Old 07-28-2012, 08:20 PM   #4 (permalink)
Thank you Billjohn, I guess i need to start with 33s. I know that the bigger tire the more likely it is to replace parts. I want to put a lift and know when people say budget people think cheap, but i want to know what lift will do this. If it cost then so be it. What wheels or offset do i need to run 33s also.
Old 07-28-2012, 09:14 PM   #5 (permalink)
Here is what you want for to set up for 33's:
TT SPOA w/ML's
Or if you want to go for a smoother ride, go YJ's:
TT SPOA YJ w/ML's
Bill
in old El Paso...
Old 07-28-2012, 10:51 PM   #6 (permalink)
Great picture !!
Your rig has changed some since late 90s.
Looks very able.
What skid plate do you use ?
Old 07-29-2012, 09:02 AM   #7 (permalink)
This is the one I ran for many years.
But once I went to a center (t-case) mounted e-brake I had to try something different to accomodate the disc brake rotor. I now run a Trail Tough Mighty Kong that I have added to, to cover the rotor. Brent has told me (after I 'customizrd' the 'Kong) that he now has a full plate that allows for the rotor.
And for the gas tank...
Bill
in old El Paso...
Old 08-04-2012, 09:56 PM   #8 (permalink)
I see these 5" and 6" spoa kits, like the Rocky Road kits. What size tire can you run on them? Are they considered the entry level kits? These kits are a lot less in price than those you recomended, does that mean that they are a cheaper quality?
Old 08-04-2012, 10:22 PM   #9 (permalink)
When going taller than a SPOA, it is cleaner (safer) to go with taller springs. To go cheaper, some use stock springs and make the perches taller. What's worse, is some folks also sacrifice attention to detail... bad combination.
Remember that going bigger than 33's will take a stronger axle. Why skimp on springs at that point.
Bill
in old El Paso...
