other than sami rear??? - Suzuki Forums: Suzuki Forum Site
Old 05-27-2012, 05:42 PM   #1 (permalink)
rotosam67 is on a distinguished road
Default other than sami rear???
Hello again !!! I will like to update the rear on my sami!!! i'm going with 2wd...so my Q' is!!! what rear can I inst in my sami, with disc brakes with no or little problem??? or I'm going to cut and re-spline one to fit!!!! input!!!please.
rotosam67 is offline   Reply With Quote Quick reply to this message
Old 05-27-2012, 07:56 PM   #2 (permalink)
2WD, you could put just about anything in it.
I would look for a late 70's Jeep Wagoneer. You will get a Dana 44 with the right offset for the Zook and more strength then you will ever need.
Bill
in old El Paso...
Old 05-27-2012, 08:52 PM   #3 (permalink)
I was looking at a Ford explore 8.8 with 373 gears and the off set is the same as the Samuel!!! But I will need to narrow! !! It will be good cuz the rear disc and posi.
Old 05-27-2012, 08:56 PM   #4 (permalink)
Nice.
I am used to building rock rigs, and the Wagoneer axles are bulletproof (front and rear) for under a Sammy. Going 2WD opens up lots of possibilities.
Bill
in old El Paso...
Old 05-27-2012, 10:08 PM   #5 (permalink)
I'm sure the Dana is bullet proof!!! but the 8.8 is a good rear and like it said I will have 3.73,posi unit,and rear disc brake...I was hoping not to do a lot off work but I guess it will be for the best.
Old 05-29-2012, 12:38 AM   #6 (permalink)
Gallery: 3
Garage
The 8.8 is an OK at best axle. It's to wide and has week flanges.
The 1971 and earlier CJ5 rears are the correct width, offset, and the 44 has every gear set in the world available for it. The disk conversion for the 44 is cheap as well.
72 and later are a centered axle (you will need one once you remove the transfer case)
373 gears stock correct width and cheap.
The Wag is 58" wide. A bit on the wide side.
You will be hard pressed to find a better axle than the cj5 44 for your aplication....
It's what the Viper is running........Boxcar...
Boxcar is offline   Reply With Quote Quick reply to this message
