Small bolt to large in tranny shifter? - Suzuki Forums: Suzuki Forum Site
Old 05-18-2012, 07:55 PM   #1 (permalink)
Spookyzook is on a distinguished road
Default Small bolt to large in tranny shifter?
I found a used gear shift with the transmission top housing. I understand that my 88 model Sami has similar design. The used one that I found is in excellent shape.
Question; Will the newer top housing bolt to the top of my transmission? I want to know before I buy. Is the slot on the ball of the shifter being wider and the bolt being bigger the only difference? Will the holes match up on my transmission? A direct bolt on? The top shifter plate looks identical, but I want advice on this.
Many thanks!
Spookyzook is offline   Reply With Quote Quick reply to this message
Old 05-18-2012, 10:21 PM   #2 (permalink)
caseyjones955's Avatar
I didn't know it but when I bought mine the small bolt had broken off and fallen into the transmission and broken a few teeth off the counter shaft 5th gear. I discovered this when I drained the oil and its mangled carcass fell out.
I just got the big pin bolt for $3 and tapped out the existing housing and used a dremmel to carefully widen the shifter slot which was already badly damaged by a threaded bolt forced into the housing. Not picture perfect but about $80 cheaper and feels pretty damn nice, tight and smooth.
I was told by one of the reputable Samurai parts vendors that the bigger pin stuff is a direct bolt over and if you have the $$ I would recommend doing just that instead of being a cheapass like me .
Tony
Old 05-19-2012, 02:59 PM   #3 (permalink)
Ok thanks Tony!
I was hoping that to be the case. I just want to make this as lasting as I can.
Old 05-19-2012, 03:28 PM   #4 (permalink)
You are welcome.
I have already enjoyed what can happen if it fails by savoring the replacement of hard parts in the transmission. A joy to be sure!
I will never go w/o the bigger bolt setup now.
Tony
