Suzuki: low beam Help :S - Suzuki Forums: Suzuki Forum Site
Old 03-26-2012, 09:16 AM   #1 (permalink)
Rhys Hollyman is on a distinguished road
Default Suzuki: low beam Help :S
hi i have a 1988 Suzuki samurai with h4 bulbs in new fittings i have had them in for about 10 months and every once in a while the low beam wont work but comes back on after bout 5 mins of driving on high beam, but now the low beam wont work at all i have tried every thing get i working again: fuses, replaced the bulbs checked the loom and im stuck.
so any advice on what it could be would be greatly appreciated because i keep getting flashed
thanks in advance
Rhys Hollyman is offline   Reply With Quote Quick reply to this message
Old 03-26-2012, 10:32 AM   #2 (permalink)
Have you checked the combo switch?
Old 03-27-2012, 05:41 AM   #3 (permalink)
yea i connected it too another one and it still did it. because i have one in bits i just connected it to the indicator stalk console
Old 03-27-2012, 09:43 AM   #4 (permalink)
Here's the thing - You have +12V from the fuse to the bulb common terminal, and then through the filament, through the wiring to the switch and then to ground - assuming that the high beam works, we can eliminate the +12v feed and the fuses - your problem HAS to be the bulbs, the wiring or the switch.
You have replaced the bulbs - that leaves the wiring and the switch - find the headlight wiring where it connects to the switch, you should have a red and a red & white wire - ground them one at a time - the red should be high beam, the red & white low beam.
If the lamps do not light the problem is between the connecting you're working at and the lights, if they do light the problem is between the connector and the switch.
