Alternator/fan belt keeps breaking - Suzuki Forums: Suzuki Forum Site
Old 03-13-2012, 05:14 PM   #1 (permalink)
Bryce Kimberling is on a distinguished road
Default Alternator/fan belt keeps breaking
Have a 2002 1.3 L Jimny here in Panama. It's been trouble free until recently. I just replaced the 4th belt in as many months. Everything seems to be aligned perfectly, proper tension, etc. I will hear an unusual noise and then the alternator light comes on. On one occasion the belt actually burned so bad the engine compartment was black with soot. The local mechanics are mystified. Any experiences with this problem? Any suggestions? Help!
Bryce Kimberling is offline   Reply With Quote Quick reply to this message
Old 03-13-2012, 10:34 PM   #2 (permalink)
johnfromperth is on a distinguished road
Sounds like something seizing up and breaking the belt. Have you checked the alternator bearings and the water pump bearings to see they are free running and not worn or grabbing?
johnfromperth is offline   Reply With Quote Quick reply to this message
Old 03-14-2012, 09:44 AM   #3 (permalink)
caseyjones955's Avatar
In the absence of any other explanation, I believe I would remove and load test the alternator on a bench. I would wonder if it isn't dragging hard when placed under load. My experience of this problem was on a Fiat 124 Spyder but symptoms were the same (I believe diode trio was out but cant recall for sure, it still charged...sometimes).
Tony
Old 03-17-2012, 11:26 AM   #4 (permalink)
Default Breaking alternator belt
replaced the bearings in alternator. Water pump next. Appreciate the replies and suggestions.
Old 12-22-2012, 10:15 AM   #5 (permalink)
Jojoboy is on a distinguished road
Unhappy Fanbelt problems on 04 Jimny
Hi I have a similar problem with my 04 Jimney, 3 fanbelts in quick sucession. I changed the altenator after the 2nd time but belt has gone again after just a few miles. Did you solve your problem? & if so any advise?
Jojoboy is offline   Reply With Quote Quick reply to this message
Old 12-22-2012, 09:55 PM   #6 (permalink)
I finally got a mechanic to address my problem and so far so good. His diagnosis:
The Jimny had sat unused for over a month in the humidity of Central America and the edges of the pulleys had corroded to the point they were abrading the belts. He showed me and they were indeed rough. After an hour of sandpaper and a wire brush attachment on my drill they seemed to be smooth again. We replaced the belts with original Suzuki belts and I haven't had any problems for several months. I think regular usage keeps the rust away.
Hope this helps.
Old 12-24-2012, 09:51 AM   #7 (permalink)
Default fanbelt problems on 04 Jimny
Many thanks for describing your solution. After the Christmas holiday I will check out the pully wheels for ware. In the mean time I'm going to order belts from Suzuki.
